Question about Keurig B50 Coffee Maker
My keurig keeps shutting off
The power light goes out every time I useit and I have to turn it back on,as a resultthe heating light has to start up all over again..and the sensor does'nt fill the cup up all the way,when i press the larger cup icon....can I return this for a new one???
  • 4 Answers
SOURCE: Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Posted on Jan 06, 2008
SOURCE: My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Posted on Dec 16, 2009
SOURCE: keurig turns off after making only one cup, when
I just solved this problem with my Keurig Plantnum. It seems that the valve that lets the water in is sensitive to clogs or sticking. Or perhaps like me, you have very hard water and calcium is starting to build up. Anyway, what worked for me was filling the resevoire all the way and turning the unit on. Then while the pump was buzzing I lightly jiggled the reseviore and all of the sudden the water level started to go down.
Posted on Jan 25, 2010
  • 60 Answers
SOURCE: my b77 keurig coffee maker keeps shutting off
Call keurig 1800 cup brew
Posted on Mar 23, 2010
  • 60 Answers
SOURCE: Keurig elite will not fill the cup all the way.
Time to descale
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
Heater turns on and heats garage to set temperature, than shuts off. when the temperature drops, the unit kicks on again. everything starts working again but only for a few seconds and than shuts off. it...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor.If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 11, 2010 | Mr. Heater Natural Gas Garage Heater -...
I have a newer tappan heater and get 4 blinks on led for error code the unit starts up fine and has flame but flame goes off when blower kicks on
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 26, 2010 | Heating & Cooling
Have a ruud achiever 90 plus furnace. the flame goes out after the igniter quits. any ideas
Nov 26, 2010 | Ruud UBHC Air Conditioner
Induction fan motor cycles on and off , with no call for heat
Rheem 3204-80D furance. Turns on and fan starts. Then in about a minute the fan shuts off.
My goodman furnace keeps lighting for about 10 seconds than goes out lots of clicking sounds
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad igniter what I see most of the time is the following sequence of operation:
Solution: You probably need to purchase and install a new igniter. I would suggest that you inspect your igniter closely for cracks. Make sure you do not touch the igniter with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, roll-out switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
NATE, NCCER, PHCC,HVAC Certified Instructor
Oct 25, 2010 | Heating & Cooling
Keurig B50 Coffee Maker Logo
232 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
