I need a manual for recently installed Siemens underfloor heating in bathrooms and kitchen - seem to have thrown it/them out with the rubbish.
The instuctions are very good on this website:
www.en-equip.co.nz/brands/siemens/underfloorheatingcontrols.htm
The attachment you need is called RDE Programming Instructions
Posted on Jul 19, 2009
  • 3 Answers
Try http://safemanuals.com they have tons of manuals. Free
Posted on Jun 11, 2008
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
It permanently has 22c displayed in temp window. I have all setpoints at 7c
Something is stuck.(that sucks) Need some info-Mgfr.,model#, and during the mean time find the power breaker or unplug it for 5 to 10 minutes. This may reset the ops. Have a nice day.
Jan 11, 2016 | Heating & Cooling
I want to turn off my electric underfloor bathroom heating completely and don't know how.
There should be a fuse or breaker that would turn that off. It should be on one circuit by its self for the bathroom heating system. If its a breaker just flip the breaker switch.
Apr 21, 2015 | Electric Hardware & Accessories
Siemens underfloor heating keeps flashing 0.5degrees & the floor is HOT! What is wrong?
There is a good possibility that the controller is not set up properly.
The instructions are on the web.
Jun 02, 2012 | Computers & Internet
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Siemens underfloor heating control panel clock keeps resetting
A common problem with a particular batch of thermostats, We have sold hundreds of them .The reset occurs with high humidity eg steam. This resets the unit. The solution is to use circuit board sealant on the back of the circuit board and problem disappears forever.
May 18, 2009 | Heating & Cooling
Siemens underfloor heating sdosent work I set the program or put it on continuous and the tiled floor dosent get any hotter
check your circuit breakers to see if the floor is getting power to it. Consult your operation guide to see if there is an internal fuse.
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
607 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
