Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
There is no agitation. Water fills up and you can hear the motor turning but no agitation. The sound is not great
  • Whirlpool Master
  • 2,605 Answers
Hello, Welcome to FixYa.
It sounds serious...but it's not likely, especially taking into account the motor is running. That indicates the motor, lid switch, timer, all those are ok.
The actual problem is likely just a broken drive coupling, a $15-$20US part, # 285753A. If it is defective/broken it will prevent the washer from agitating and spinning, just as you described.
It may even fracture in a manner which can sound pretty bad, like it is serious.
Check out this link from youtube...
http://www.youtube.com/watch?v=WLPGs2UMUJc
There are helpful "how to" videos to guide you in accessing and replacing the coupling. This video may have slight differences from your machine, but the basic principle is the same.
If that doesn't assist you adequately, let me know.
Hope that helps and if so please take a moment and rate the solution favorable.
Thank you for choosing FixYa today.
Good luck,
macmarkus :)
Posted on Jul 16, 2010
5 Suggested Answers
SOURCE: Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Posted on Nov 04, 2008
  • 68 Answers
SOURCE: Washer fills with water but after filling motor
Check the coupling between the motor and transmission. It probably needs to be replaced.
Posted on Nov 14, 2009
Testimonial: "Guru hit the nail on the head. Many thanks"
  • 949 Answers
SOURCE: Will not agitate after water fill up. Motor makes whining sound.
It sounds like it could be the coupling that has worn or broke, to verify this put the washer in spin, let it drain the water out (if it will) then turn off the timer or open the lid, wait 10 seconds or so then start back up in spin. If the washer just whines then it is most likely the coupling. I have put together some instructions on this if you follow this link it will tell you more about it and how to replace it if you wish. Let me know if this helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Posted on May 06, 2010
  • 1937 Answers
SOURCE: Kenmore 80 series model 3110.24852300-the washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Oct 01, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
My washer buzzes when knob is pulled but it will spin just not fill or agitate
sounds to me like either the water faucet at the wall is shut off or their is some sort of restriction to the pipes not allowing the washer to fill
some on here may say that the buzzing will be the motor but since it spins i say bully to them the motor only knows to go to spin or agitate rotation based on on what the timer/control tells it to do if it will turn one direction it would turn the other direction as well. So definently check the water supply to the washer
Oh the buzzing is the solonoid on the valve opening the valve yet since no water coming in you hear the buzzing while you wouldnt hear it since it would be drowned out by the sound of the water coming in
Jul 19, 2011 | Washing Machines
Washing machine fills, agitation fails
Problem solved. The short version; there was a toddler's sock stuck in the water pump. Once removed, the machine works great.
FYI - After I removed the outer casing, to drain the water, I removed the BOTTOM hose from the pump first (TOP hose was unrestricted flow and my spill pan under the washer wouldn't have been able to keep up with the volume). The water trickled out steady and slow, which made me think 'obstruction.' Once the water drained, I pulled off hose #2 and there was the sock. The motor turns both the transmission (agitation/spin cycles) and the pump. The blocked pump was preventing the motor from turning, and the safety mechanism was kicking out so as to prevent the motor from burning up. I checked the motor and transmission while I had it apart, just to verify these other parts could move on their own and had no issues. They were fine. There's something to be said for these older washers ... even a 'no experienced idiot' like me can figure out how it works. Hope this is helpful to someone else out there.
PS - The hardest part was getting the washer casing back into place.
Jun 29, 2009 | Whirlpool Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
does it spin?
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
202 people viewed this question
Dan Webster
Dan Webster
Sal De
