Question about Craftsman Garden
Changing gear oil on a 917.254241 craftsman mower
  • 49 Answers
SOURCE: craftsman mower 917 273201
Check the seat switch for the running problem. Disconnect the switch and jump the harness with a piece of wire, and see if the tractor stays running. If so, then the switch is bad. As for the charging problem. Test the voltage regulator. Start the tractor and put a volt meter across the battery. Red to red and black to black. Run the RPM to full throttle. You should have a reading of 14 to 14.5 volts. If not, the regulator is bad. Hope this helps.
Posted on Feb 11, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 148 Answers
SOURCE: Craftsman II mowre oil capacity and filter type
Go to www.managemyhome.com and manual for your tractor. All you have to do is type in the model number without the period between the 917 and 254 i.e. 917254610.
Posted on May 19, 2009
  • 376 Answers
SOURCE: Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
  • 24 Answers
SOURCE: Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Posted on Aug 23, 2009
What is used to lubricate the transaxle of craftsman gt5000 garden tractor. Is it grease only or 80-90w oil?
If tractor is _very_ old (and/or worn), you can't go wrong with 90-145w gear oil. Someone may have used grease for a bad leak, but heavy gear oil should work for you. Remove as much grease as possible without using solvent, and then fill with heavy gear oil. You'll be ok. (Later on check level and ''top-off'' if necessary).
Aug 16, 2015 | Craftsman Garden
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Tansmission oil type for model# 917.254740
Your Craftsman is equipped with a Agri-Fab transaxle, the predecessor to the Hydro-Gear brand. The recommended oil is 10w-30. Unfortunately, the transaxle on your craftsman tractor is not serviceable. It is sealed for life. The only way to change the oil is to remove the unit from the tractor, tip it upside down and drain the oil out the reservoir plug.
Jun 16, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
My Craftsman 26hp tractor is running extremely ruff, I have replaced the plugs Confirmed that the plugs are working. It runs ruff at all speeds. The tractor was runing just fine a few weeks ago
You've changed the plugs have you checked the oil and air filter if not you need to because if not it might need changed and it may be low the rider my father gave me ran ruff and would die in 5th gear and I changed the oil and air filter now it stays going in all gears.So my suggestion to you is to to change the oil and air filter I am not a pro but I have had to keep my mowers going no help from anyone so I had to learn so if you don't agree with me check with a repairman.
Apr 12, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
42' mower locks up in gear
there are a several gears in the axle that causes the axle to go slow or fast & as well backwards take out rearend & tear it apart & look at gears or have someone look at it for ya
Nov 08, 2009 | Craftsman Garden
Oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Apr 08, 2009 | Craftsman Garden
Garden Logo
66 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
