Question about Coffee Makers & Espresso Machines
Leak from just at the bottom of the water heater (where the tube joins the heater).
The tube probably has a crack and is leaking.
As you may know by now cuisinart does not sell internal parts for thier coffee makers. I found mcmaster.com has the high temp tubing. try part number 5236k73
cost is about 2.50 per foot.
Note that in the coffee maker, there are two tubes, one is the cold water going down to the heater and the other tube is the hot water going back up to the top. The cold water tube has a flow regulator in it and this should be cut out of the old tube and placed into the new replacement tube (going the same direction).
Posted on Aug 11, 2010
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
Jan 09, 2015 | Water Water Heaters
Tip
Find your only getting Luke warm water @ your faucets??
This is a common fault with new to used installed waterheater.
It is call a diptube ,made of pvc in part description. It is located on cold inlet,top of waterheater.
Malfunction of dip tube is usually a fracture caused by age mostly,or faulty install when new and tube was exposed to high heat from welding .
This tube allows the cold water supply to flow into W/heater and exit at bottom where it is heated while pushing already heated water to hot side and to your faucet. If this tube is defective ei...cracked the cold will [leak] mix with the hot before reaching bottom to be heat..thus lukewarm water syndrome. Solution $8 part H/depot>remove coldside copper fittings and pull white pvc out,about 4feet long,less rotted area, install new 3/4 inch pvc dip tube with flange up.
Thanks jj505 The HomeRepairman
jthomefix@gmail.com
on Apr 13, 2009 | General Electric GE SmartWater Household...
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
Nov 25, 2012 | Rheem Water Heaters
Water flow out from the overflow tube
open the sunroof ,stand on the seat then you can still breath when your escort fills with water
Feb 19, 2009 | 1998 Ford Escort
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
My 7142 leaks
There are a few hose connections inside the unit related to the heater element. Water flows from the reservoir down into the unit, takes a turn into a tube with the heater element wrapped around it, then turns back up into the mister area. Any of the four connections (base to first elbow, elbow to heater tube, heater tube to second elbow or second elbow to base) could be leaking.
The white ring around the mister disk cracked on my unit, letting water leak out the bottom as you describe... Take a close look at that.
It's also possible the base itself is cracked somewhere... Look closely at the mister and reservoir areas of the base for cracks.
Dec 16, 2008 | Air-O-Swiss U7142 Humidifier
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Jan 27, 2008 | Refrigerators
Coffee Makers & Espresso Machines Logo
209 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
