Question about Dometic Heating & Cooling
I have a dometic roof top a/c when I turn it on the compressor make a noise and shake a little for a second but it doesn't start after 30 seconds it try again but it doesnot cool at all, it keep doing this until I decide to turn it off, thank you for your help
  • filadelfia02 Jul 16, 2010
    I did put a new capacitor
  • 57 Answers
It's either low on refrigerant and the low pressure switch is keeping it from starting, or the compressor doesn't have enough juice to start on it's own, which might need a new start capacitor.
Posted on Jul 16, 2010
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
How can I tell if the compressor is coming on on my Coleman 13500 roof top A/C unit? It blows air but not cooling. Thanks
When the compressor starts you will hear the unmistakable noise associated with it...there is a definite hum from the compressor...check the t-stat on the unit... they often go bad..
heatman101
May 19, 2011 | Dometic Rooftop RV Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
I have an old type roof top a/c unsure of the model or make no tags. It starts and runs for about 60 seconds then stops but the compressor still runs. I replaced the run capacitor with no luck.
You might try removing the cover on the compressor where the wires hook up and see if there is a little black overload, usually the common wire is connected to it and then there is a wire from it to the common terminal on the compressor. If you have one of these overload protectors they can get weak or the wire can be loose causing a high amp draw.
Jul 24, 2009 | Dometic Rooftop RV Air Conditioner
Fan stops turning after about 30 seconds
this sounds like one of your capacitors has failed
using an insulated screwdriver and, power not applied remove the spade connectors from one of the capacitors then short the capacitor to ground to discharge it replace the spade connectors apply power and, turn it on if the problem changes replace the capacitor (a bad capacitor usually is "bulged")
there are usually two capacitors a run and, a start
May 29, 2009 | Dometic Rooftop RV Air Conditioner
Have Duo Therm roof mount A/C. Fan runs but when compressor tries to come on it just has a hum sound for about 10 seconds then after a short period of time it tries again but will not kick on
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Feb 25, 2009 | Dometic Rooftop RV Air Conditioner
Compressor tries to start but want
hi,
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Aug 21, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
412 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
