Question about Canon PowerShot S400 / IXUS 400 Digital Camera
When switched on, after few mins the camera screen displays 'E18' and it goes off again. Apparently the camera fell down before this error.
    Novelist:
  • 178 Answers
The e18 error is quite common, yeah and annoying too.
Here is a blog about it with some good info:
Canon E18 Error Repair
Same company offers repair for a very good cost! https://www.teleplancamerarepair.com/quote/cart.asp?iProbID=6&mo=445
Posted on Jul 16, 2010
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Camera will not switch on/off properly, and "E18" appears on the screen
"E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 06, 2010 | Canon PowerShot A95 Digital Camera
Camera does not power on. I get three beeps,
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 22, 2009 | Canon PowerShot S2 IS Digital Camera
Camera got stuck
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Mar 12, 2009 | Canon PowerShot S80 Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
E18 error pops up and to make it worse the screen is green and its making a lot of beeps
http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
The better solution is to send it to Canon's service people.  They can fix he problem is the fixes at the above site won't work.
Mar 05, 2008 | Canon PowerShot A520 Digital Camera
Problem with my camera
Your lens is jammed, and needs to be repaired or replaced.
Sep 04, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
