Question about Waring WMK300 Professional Belgian Waffle Maker
Waring Wafflemaker power light comes on but won't heat up
  • Anonymous May 26, 2008
    Waffle iron power light is on; but heating element won't heat.
  • Judithallen Jun 26, 2008
    I have the same problem--I bought my wafflemaker--used it about 5 times, it stopped heating up. So I called and sent it back and got a replacement; and guess what??? I made one waffle---and it would not heat up!!! Yet a second time. I am not electrically challenged--checked the fuses, used a 20 volt outlet - no luck. Well, it cost me $20 to send the first one back--and I have no intention of sending this one back. You obviously have this problem as others experienced it--can you not figure out how to elminate the problem????
    Problem Solver:
  • 8 Answers
My just over 1-year old WWM200SA did the same thing while I was cooking with it (used it about 5 times). I found a solution under the WWM200PC thread that the thermal fuse blew early. I tested mine and that's what happened. It is a cheap part, but I called Waring Customer service (800-269-6640) instead and they said to send it in for replacement.
Posted on Jun 14, 2008
My Oster wafflemaker doesn't get hot! The lights are on but only gets warm
One or more of the heating elements are not activating. If you take it apart, perhaps you can do a continuity test on each element to see which is bad. I don't believe they sell element replacements so your only choice would be a new purchase or warranty.
Jan 29, 2013 | Kitchen Appliances - Others
The waffle maker has two lights. A red one which indicates te power is on and a green one which lights up when it reaches the desired heat (and the thermostat circuit opens and the device stops heating...
There seems to be a problem with your thermostat or temp cutout switch if the machine is getting exceptionally hot. This could explain the green light not coming on.
Jan 26, 2011 | Krups FDK2 Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
My wafle maker no heat
Hello Judith. I fixed my waring wafflemaker by relacing thermal protector fuse (catalog# 270-1321) for $1.69 at Radio Shack. You can fix this if you're handy and can solder or splice in new fuse. How to: Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation, Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Link for fuse:
Jan 27, 2010 | Kitchen Appliances - Others
Waring Pro Waffle Maker
Had same issue,found a looks like diode on the black wire leading to the heating elements.It is open circuited.Needs replacing.It is not a diode...maybe a voltage circuit protection device.It is crimped into the black wire under the sleeve clamped down near the handle.Going to radio shack to get a idea,replacement.
Jun 02, 2009 | Waring WMK300 Professional Belgian Waffle...
I posted the same problem (no heat) but may have found the answer. There is a component that cuts off the power if the unit gets too hot. My best guess name for it would be a "thermal fuse". If it heat. (located behind one the waffle grids inside unit..silver and black)(behind the other grid is what I believe to be a variable resistor that varies with heat..used to set heat levels in conjunction with the dial on the front of waffle maker)
When thermal fuse goes it needs to be replaced. BUT I WONDER
what caused the overheating? I will go down to Radio Shack and buy the "thermal fuse" according to the data on the old "fuse" and put it in...then ????waffles or sparks???
the old fuse has printed on it: sheng ping SPF240 TF240 Deg. Celsius 10 amps 250volts 073 and some symbols
Wish me luck
Feb 24, 2009 | Waring WMK300 Professional Belgian Waffle...
No heat on brand new Waring WMK300 waffle maker
Lots of appliance makers include a 1 800 number with the paperwork that comes with an appliance.
I would try to find that number and call them. They owe you a replacement unit. If you can't find the number do a Google search for Waring and they should have a tel number and/or a "contact us" place to send and email.
Good luck Loringh
Sep 21, 2008 | Waring WMK300 Professional Belgian Waffle...
Heating element
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Feb 25, 2008 | Waring WMK300 Professional Belgian Waffle...
Belgian Waffle Maker Problem
Here is what is happening, and if you're out of warranty and so inclined how to easily fix it yourself.
Make sure you are unplugged from the wall before doing anything or you will get shocked. You do not need to take the bottom cover off the base. You do not need to take the top plate apart (they super glued one screw in the top plate (lid), you'll strip out the screw head trying to remove it anyhow). All you need to open is the bottom plate, it has 4 screws in it you will see when you open the lid, these screws are not super glued and will come out. 2 on each side in the back, 2 in the center of the front, long screws go in the back, short in the front.
There are 2 white wires, 1 black wire, 1 green wire that run up the neck of the waffle maker to heat the top and bottom heating elements. The 2 white wires are neutral, the green wire is a ground, the black wire is power.
This black wire runs from the electronic control board in the base of the unit, up the neck in the rear, through a thermal fuse, to the bottom element then jumps up to the top element. All you need to take apart is the bottom plate, the part you pour the batter into. It has 4 screws you will see when you open the top plate up, take those out and you are going to find the black wire is covered by a white rubber like tube about 3 inches long. In the center of this rubber insulation there is a metal clip with a single screw. Take that screw out, pull off the metal clip and slide (don't cut) the rubber like insulation back.
You will find the black wire is crimped onto a silver metal bullet looking component. This component is called a "thermal fuse", its designed to fail at 240 degrees C. Its obviously a design flaw and the thermal fuse is under rated for the actual heat within the device. Its also a one shot fuse, so when it blows it kills power on the black wire from going to the top and bottom plates, thus no heat. It is not resettable.
I didn't even cut mine out (Waring is very skimpy with their wire, they don't leave you even a hint of extra wire to work with). I just tightly twisted the bare metal wire on each side of this component like a bread tie leaving the blown fuse in place. Then be sure to slide the rubber like insulation back over all of the bare metal so it is covering the black wire on both sides. If you don't it will short out and blow your house circuit breaker when you turn it on.
This thermal fuse was probably a requirement of the UL Listing. Its over kill, everything in there is metal so if it over heats in that area there is nothing flammable to burn. If a run away temperature occurs the wire itself will melt, short out and trip your house breaker. There are stacks of these units brand new with this same problem anyone reading this is having, the thermal fuse is under rated, the fix is simple.
Aug 20, 2007 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
453 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
