Question about Plumbing
I've made a 10m water level using two 5m lengths of clear 6mm internal diameter pipe joined in the middle with a proprietary tube connector. I looped the tube with both ends next to each other and the centre much lower. I filled the tubes with coloured water and made sure all the air bubbles escaped but the liquid fails to equalise in the two tubes! Both tubes are open to the atmosphere but the level in one is about 50mm above the other! I've repeated the filling procedure about 10 times now with the same result, any ideas?
    Brigadier General:
  • 3,006 Answers
The internal diameter is notional and if the two lengths you have used came from different production batches then their average internal diameter along the length of one half may be different to the other. The fact that there is such large ratio between the length of the tube and the internal diameter only makes matters worse.
You need ideally to source a single 10m length and to select a larger internal diameter to maximise accuracy: 10mm i/d will be better but if you can cope with the extra volume of liquid then 15mm or even 20mm will be much more accurate.
Posted on Jul 28, 2010
I have a Hoover Contour HE430TF fridge leaking water to the bottom of the crisper. There is no internal drain hole. Hoover has no record of a 20 yr old model & is no help. How can I fix the problem?
it's not leaking water.. it's condensation running down the back of the fridge.. normally this is channelled into a hole that has a tube on it, that allows the water to go to a drip tray on top of the (warm) compressor, which then evaporates it.. Please re-check for a "V" shape moulding on the back if the fridge.. there SHOULD be a hole smack bang in the middle, which may have clogged up in the pipe with gunk, causing water to refreeze and block the hole completely.. best to do a full empty and clean, and use a chopstick, or better still a cheap pipe-brush from the £ shop, to clear that tube (about 1/2 inch diameter, or maybe less.)
Apr 24, 2017 | Hoover Refrigerators
What is a water level
A water level is a long clear tube filled with water within a couple of inches at either end.( No limit to length.) Mark water level at one end and hold it to what you're measuring. Walk the tube to the next spot and hold it up When the water is at the same spot on the end tube, both spots are the same level. I think the Egyptians used a version of this to build the pyramids.
Jun 30, 2014 | Measuring Tools & Sensors
The water dispenser is not working. I here a click but the water is not being pumped. It is making ice. I have replaced the filter. I have confirmed the reserve the line is not frozen.
I often find this if I put my ice compartment onto high setting that the feed line freezes quickly. If you are sure this is clear (you can get water through the entire length via other means) then I would trace back to the start of your pipes look for leaks at joins from source to outlet, blockages/crimps etc. I also found on one of my lines that the transition near the door hinge was both leaking and crimped.
Remedy = I bought a larger bore plastic tube that would not quite press fit over it and bored it out lengthways with a drill bit the same diameter as the outer diameter of the pipe to perform a splice. The reaming leaves some debris which helps seal everything and if you get a good 3" overlap you will be water tight. I recommend to use an elbow rather than an in-line connection if your pipes change direction but be careful where you choose to put it. other than that if your model uses a pump? Beyond that, I am stumped.
Dec 28, 2013 | GE PFCS1RKZSS Bottom Freezer French Door...
I need help finding a waterproof connector for a shielded coax wire approx. 5/32" in diameter.
If you cannot find a water proof connector from a radio parts shop may be you should consider using some shrink electrical spaggetti . Cut a length and place it over the cable--connect up the connector then shrink the tube down onto the cable around the connection. It will be as water proof as you will get. Only problem is that if you want to disconnect and reconnect the fitting you will have to replace the tubing.
Sep 22, 2013 | Cars & Trucks
Ween two 15mm bidet pipes which are about 3 inches apart and slightly at an angle
I don't know all of your situation, but I have found 1/2" flexible connection lines braided or neoprene very adequate. Another suggestion is to use 3/8" plastic tubing with appropriate fittings. Hope this is helpful.
Apr 21, 2017 | Plumbing
How to change the hose that leads to water dispenser. has a hole and is located on the back of refrige
Typically that line is 5/16 diameter and depending where its broke a connector can be used to to cut out leaking section and use connector to join. The part number for the 5/16 inch connector is WR02X11330 typically the tubing to icemaker(not door dispenser) is 1/4" diameter and it is sold at Lowe's HomeDepot ect ect usually they dont sell the 5/16" diameter but in some case have both the tubing and connectors in stock. The connector part number i gave you(WR2X11330) can be purchased from your local appliance parts store if Lowe's HomeDepot doesn't have it. This link http://www.go2marine.com/product.do?no=52075F&WT.mc_id=gb1&utm_source=googlebase&utm_medium=productfeed&utm_campaign=googleshopping sells the tube by the inch their part# for it is 52077 MFR#1500566FT
I hope this will help you to repair your leak,
Gene
Aug 12, 2011 | Kenmore Refrigerators
Water takes 30 sec to cover 10m from heater to tap
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You are talking about length of time to get hot water from water heater.What diameter pipe are you talking about? What type of faucet do you have?
1/2" pipe has inside diameter of .54" and holds 1.2 gallons per 100 feet
10 meters is 32 feet and holds .4 gallons
Average faucet puts out 2 gallons per minute, so 30 seconds you should get 1 gallon of water.
Put a bucket under faucet and check amount of water flow.
Assuming you draw just hot water from the faucet, then 30 seconds is slow for receiving hot water.
If you have single-handle faucet and raise handle straight up in middle, then you are drawing half hot and half cold, so it would take 30 seconds for hot to arrive.
If hot water is slow, the problem might be crossover.
http://waterheatertimer.org/Crossover.html
or low water pressure due to clog in water line
http://waterheatertimer.org/Low-hot-water-pressure.html
Other problems could include clogged water filter, clogged water softener, defective pressure valve, and low water pressure.
Sources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 10, 2011 | Bosch Outdoor Gas Tankless Water Heater...
Can i bypass the heater core?
Yes. You would need to join both hoses from the firewall into a loop to circulate the water back into the engine. You will need to measure the hose sizes and make a connector. You will need to clamp the hoses to the connector.
If you use copper tubing, you should flare the ends to insure a good seal.
May 09, 2010 | 1995 Ford Escort
Volume of water in pipe work
3.14 x Diameter x Diameter / 4 x length= Volume in Cubic inches Diameter and Length are in inches.
Multiply the above volume by 0.004 to get gallons.
Jun 11, 2009 | Plumbing
Diplomat 8512 Washing machine - water spilling out of detergent tray? Here's hoping for a simple solution.... When I start any program the water fills up the drum and then starts to pour out of the...
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
Nov 07, 2008 | Washing Machines
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
