Question about Frigidaire GLWS1233A Top Load Washer
Agitates & spins on wash
When washing it seems to spin also then it becomes off balanced
  • 121 Answers
The clutch to the transmission is partially stuck...usually lubrication of the moving parts will help.
Posted on Apr 21, 2008
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
My Hoover top-loading 550MB 5.5Kg washing machine is clicking only as it progresses through the wash cycle and not agitating the clothes. Previously the spin cycle hasn't worked and I've checked the...
Your description leads me to believe your problem is with the agitator DAWGS. Remove your agitator and check inside the agitator to see if one or more are broken off. If they brake your agitator won't work as it should. Good Luck Friend.
Feb 16, 2018 | Washing Machines
Loud noise from tub when on fast spin aquarius wma48 1400 spin
possible causes are
Overloaded Machine
Putting too many items in your washing machine at one time or washing larger items, such as a quilt, can cause your washing machine to occasionally make excessive noise. Laundry can get trapped around the agitator and will hamper its movement, causing it to work harder to spin. Stop the wash cycle and remove the excess laundry on top. Take big, bulky items to a laundromat or drycleaners to wash in an industrial machine equipped to handle such items. A washing machine is more effective at cleaning laundry when water and suds can surround the clothes and penetrate fabrics.
Defective Balancing System
GE washing machines have a balancing system that includes counterweights, springs and pistons that help to evenly distribute weight inside the wash tub. If any of the system's components break, it can interfere with the drum's rotation. Rather than spin evenly in the machine, the drum might be imbalanced up or down and produce a knocking sound. The noise might become louder and more persistent each time you do a wash load until you replace the faulty component.
Washing Machine Not on Level Surface
Place your washing machine on a flat surface, preferably a concrete slab. If the floor underneath the washing machine is sloped, even the slightest bit, it can cause the machine to vibrate when it spins and agitates. Place both hands on either side of the washing machine and try to move it. If the machine moves, then adjust its feet at each of the bottom four corners of the machine by tightening or loosening the bolts with a wrench until the machine is level on all four sides.
Jun 10, 2011 | Hotpoint Washing Machines
The agitator in my washing machine is trying and notting all of the clothes up, resulting in the machine becoming unbalanced. I have taken the lid off and wached what happens and the agitator only seems to...
Is this a GE Washing Machine? This sounds like one, it sounds like the shifter coil has failed, this it's not locking to engage the agitator. So it's basically stuck in spin mode, this way, even though the tub does not turn.
Mar 12, 2011 | Washing Machines
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Will not spin or agitate
Get the model number. It may have an off balance switch that is stuck. Try moving agitator like its off balance and then turn on.
May 18, 2009 | Washing Machines
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Spin cycle
The balancer spring are detached from spinning drum out of alignment /outbalance / replace balncer spring available in apliance center.
Jan 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire GLWS1233A Top Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
