Question about Jet 3 Ultra Power Chair
Wiring Diagram and battery hookup fdor a Jet 3 Ultra
I have searched and read several of your fixes, but I am not finding what I need. Ineedthe wiring diagram and proper battery hookup for the Jet 3 Ultra. I replaced the batteries and the chair worked fine but could no charge the batteries. Who readily has these diagrams? The manual dues not depict enough information or eexplanation to tell me what iwish to know. Can you help??
Sincerely,
Paul Delamater
    Genius:
  • 1,478 Answers
There are two ways to look at this problem, one, check the battery terminals to see if they corrode, because, if they are, the battery will not charge, the battery terminals will need to be replace.
Secondly, you will need to check the charger to see if it is receiving power, because the unit might not be receiving power, in this case, you don't expect the battery to charge, you can get a similar charger to test to see if it will charge it, if it does, it means your charger is defective, and will need to be replace.
Take care.
Posted on Jul 16, 2010
  • eed5 Jul 16, 2010
    My appologies to you I'll be 80 on the 21st of this month and I know what you have explained and I thank you very much for your effort. What I am trying to obtain is the schematics or wiring diagramof that particular unit..
    Sincerely,
    Paul Delamater
I am trying to find a wiring diagram for a Massey Ferguson 451 tractor?
Try this: Massey Ferguson 451 tractor wiring schematic Google Search
There are several wiring schematics. I would just look for what you are needing to find. If you can't read the schematic fully, please do a request for more specific info and it will kick it back to my email.
Hope this helps.
Apr 25, 2017 | Toys
89 f150 changed key switch,ignition switch,starter solenoid no power anywhere now
Do you know anything about automotive electrical ? How to follow a wiring diagram ? Basic electrical testing ? Using a DVOM - digital volt ohm meter etc.... You could go to http://bbbind.com/free_tsb.html free wiring diagrams ! Enter your vehicle info ,year ,make , model an engine size . Then under system click on electrical distribution ,then under subsystem click on power distribution . It will show 2 diagrams found . Click on the search button an two blue links will pop up .Click on the first one scroll down to last diagram . This is a diagram of ignition switch an power feeds ! Check the two yellow wires for B+ voltage . No power there would mean one of the fusible links blew . Scroll back to the top diagram ,the fusible links are shown at the top left .They hookup at the starter solenoid > There are videos on youtube showing basic electrical testing , how to read a wiring diagram , how to use a DVOM . This is how you have to find the problem ,testing !
Aug 14, 2016 | Cars & Trucks
Where can I find all the wiring for a eagle ultra II fish finder
Not sure if you mean schematic diagram for pcboard repair or just hookup diagram. here is the manual that shows hookup.
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/Ultra%20III%20_%20III.pdf
Jul 18, 2016 | Radio Communications
How can I access the wiring behind the plastic that connects to the motorized head?
If your model is a DC07 as stated there is not a separate motor that runs the brushroll. The brushroll spins from a belt that comes from the main motor or goes through a clutch assembly with two belts. If it is a ball model and the wires have severed you will need to replace the wire or wires with the proper replacement parts for it to work properly. I would need your model number to determine the proper wat to fix it.
Mar 25, 2016 | Dyson DC07 Animal Bagless Upright Cyclonic...
Powerchair motor wiring for jet 3
hi John, it;s rather straightforward , two wires for the motor two for the brake..
Motor wires are coloured black and red ...
Regards
Rob.
Feb 05, 2016 | Pride Mobility JET ULTRA 3 BLUE POWERCHAIR
Can you get me a diagram on electrical hookup?
Hello;
My name is Peter. I am a retired field service technician.
I do not know if you have a 3 wire or 4 wire connection. For a 3 wire connection you need 15 AMPS at the breaker box. For a 4 wire connection you need 30 AMPS at the breaker box.
Three wire hookup. Center wire goes to N, the other two wires are hot. It makes not difference witch of these two wires go to L1 or L2. The ground goes to the cabinet.
Check the voltage - With a volt meter between L1 & N = 220V, L2 & N = 220V, L1 & L2 = 240. These readings are general. You may get something like 210V instead of 200V
Mar 10, 2015 | Dryers
Wiring diagram
rear battery wire connects to positive red terminal,then rear battery to negative black terminal,battery terminals facing inward,front battery to other batterys positive red cable ,wire labeled front battery to black negative cable,plug wire harness into quick disconnect...page 40 of owners manual
Oct 15, 2014 | Jet 3 Ultra Power Chair
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Replace battery for the jet 3 ultra
\hmm what do u need to know? how to replace battery?if so take seat off then take off shroud and u will see batterys,make a wiring diagram of how batterys are conected before u remove them, good luck
Jan 20, 2014 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
487 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
