Question about Kichler TRANSFORMERS - PROFESSIONAL SERIES - 15PR200-SS - Stainless Steel
I have a 3-year old kichler transformer (model # k15pr600ss). Outdoor low-voltage lights are not working. Checked electric lines with voltage meter; power is going to transformer, but not leaving it. It's my understanding this professional series has a lifetime warranty.
3 Suggested Answers
jeltey
  • 44 Answers
SOURCE: KICHLER 15PR600SS
Here is a link to the specs for that trnsformer. It looks like there is only the switches for each circuit. Dumb question Are the load switches turned on?
http://www.landscapelighting.com/opencms/opencms/system/galleries/pdf/ll_spec_sheet/landscape/15PR600.pdf
This is all the info I could find on it for you. I hope this will help.
Posted on Dec 04, 2008
SOURCE: I have a Kichler 300
Kitchler 15531 has a Grasslin 24-hour FM1 timer module.
Open following links:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/modular%20din%20rail%20timers/fm1%20series%20-%2024%20hour%20and%207%20day.aspx
NOTE: View back of timer module to get voltage.
Take photo of wiring before disconnecting.
Kitchler timer does not have the override.
For example 120Volt 24-hour without override and without battery back-up is FM1STUZ-120U
FM1STUZ-120U $55 at Intermatic:
http://store.nexternal.com/intermatic/categories.aspx?Keyword=FM1STUZ-120U&x=14&y=11
FM1STUZ-120U $33 at 1000 bulbs
http://1000bulbs.com/product/3427/ELEC-FM1STUZ120.html?utm_source=SmartFeedGoogleBase&utm_medium=Shopping&utm_term=ELEC-FM1STUZ120&utm_content=Timer+Modules&utm_campaign=SmartFeedGoogleBaseShopping
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 09, 2014 | Intermatic Malibu 300W Power Pack...
Malibu 8100-0300-01
Promoters should include useful information. Not just air-head fluff.
Copy following link for actual useful do-it-yourself information such as warranty, troubleshoot, operation tips, manuals.
Aug 21, 2012 | Hardware & Accessories
My Icon bathroom fan does not work by timer I have changed timer , transformer and electrics have been checked (with certificate) What next !
Which timer do your have?
Not all timers work with fan motors?
Are you adding a new bath fan? Or are you installing a new timer?
What transformer what checked? A transformer is used to change voltage. For example you can plug a Malibu outdoor-light transformer into ordinary 120V outlet and the transformer changes voltage to 12 volts so you can safely operate lights stuck into the ground around bushes. Or your phone recharges using transformer that converts ordinary 120Volt into very low voltage entering your phone.
Practically every electronic device in your home has a transformer ... microwave, TV, computer ... but I don't know why a bath fan would have a transformer.
Add a comment, and I will respond.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/How-to-wire-timers.html
Aug 17, 2012 | Hardware & Accessories
I have a kichler 15pl300 where it does not transform from 120 Volts coming and it does not want to send out 12 V on the other side. The 120 volts has confirmed for be live.
I have been unable to locate manual for Kitchler low voltage products.
The troubleshoot page says check on-off switch, and put black tape over photoeye for two minutes, but does not elaborate on what to do.
1) Kitchler e-mail and contact information:
TechSupport@Kichler.com
Mailing Address
Kichler® Lighting
7711 East Pleasant Valley Road
P.O. Box 318010
Cleveland, Ohio 44131-8010
U.S.A.
2) Kitchler troubleshooting page has nothing:
http://www.landscapelighting.com//portal/faqs_page/portlet_landscape_faqs/cms/begin?portlet_landscape_faqsresource=/OpenCMS/sites/landscape.com/faqs/Faqs_Main_Page
Add a comment and say what you discover for others with Kitchler problems.
Open following link for Intermatic/Malibu troubleshoot:
Jun 07, 2011 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
I would like to purchase a transformer that goes to 50% lighting after scheduled full brightness timed hours. Unit needs to have phoot sensor so it shuts down completely at daybreak. Do you have a unit to...
I don't know of a timer that matches.
Add a comment with photo of your old timer
Include as much information as possible.
Is this low voltage? What brand, etc? What does timer control?
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Intermatic makes low voltage, so does Kitchler.
I don't know much about Kitchler brand.
http://www.amazon.com/Kichler-Transformer-600W-Timer-Photo/dp/B000H6VATW
Paradise low voltage
http://www.shopwiki.com/_Paradise-GL22007-Low-Voltage-600~Watt-Transformer?o=1092507953&s=3885
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dtools&field-keywords=Paradise+GL22007&x=16&y=19
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 10, 2011 | Intermatic & Outdoor Lighting Timer
I have a Model ml 44t, when the temp outside became cooler my timer would not turn on the lights, it would stop rotating at the red post.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml44t%20trilingual.ashx
-I think your outdoor plug is connected to GFI plug in bathroom or kitchen >>> check reset on GFI.
-Next, plug your hair dryer into same outdoor plug to see if plug has electricity >>> electrical plugs outside wear out quicker, and get loose wires.
-Move timer cord to the other plug
-I don't know if a bit of WD 40 would help or not .... couldn't hurt to spry some on the pins at this point ...UNPLUG timer because WD is very flammable...
-Tips from manual mention checking for burned out bulbs ... I've seen that mentioned other places and don't know if bulb problems shorten life of low-volt transformer inside the box.
-I worked with timers for years, and never seen replacement clocks or transformers for Malibu-type timers
-Timers located outside get damp and dirty ... these things cause small gears inside timers to oxidize and clog so they don't work after a while ... again, a bit of WD-40 might help
Tips copied from manual:
• Make sure power pack is plugged in. Is outlet working?
• Turn manual ON/OFF switch to "ON" or rotate dial so "ON" tripper passes time line indicator.
• Is lamp burned out? Use another lamp to test.
NOTE: This lighting system is designed to last many years under normal conditions. However, lamps eventually burn out and operating with one lamp out can shorten the life of the others. IT IS IMPORTANT TO REPLACE BURNED OUT LAMPS PROMPTLY.
Conditions beyond your control such as abnormally high household voltage due to poor utility voltage regulation will also affect lamp life.
The timer has 1 year warranty.
Oct 04, 2010 | Malibu ML88TL 88Watt Low Voltage Power...
Thermostat wires dead
If you have a split system (an air handler that blows air into your house and an outdoor unit that has the compressor and condenser coil/fan), then you should look in the electrical compartment of your indoor unit and see if you can locate a low voltage fuse. This is usually located on the control board or between the transformer and "R". Make sure you shut off the power to your indoor unit first as they will still be 240volts available there. If the fuse is blown, replace it and reinstall your thermostat. Turn the power back on. If the thermostat is wired properly with no damaged wires in the process, the system should work fine.
If there is NO fuse, then check the low voltage side of your transformer using a Voltmeter. You will have to have the power on to perform this test. Be very careful. On one side of the transformer, you will read 240volts. The other side should read 24 volts. If there is no voltage on the 24volt side, you blew the transformer and will need to replace it.
Check these items first. If you need further assistance, let us know and we will dig a lil' deeper. :-)
24%20v%20transformer.jpgpicture of a typical transformer.
The low voltage fuse could be a glass cartridge fuse (systems typically older than 15 - 20 years old). Newer systems use the same style fuses that are used in your truck or car (ATC type).
Apr 08, 2010 | Hunter 30124 Air Conditioner
KICHLER 15PR600SS
Nov 07, 2008 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
Kichler TRANSFORMERS - PROFESSIONAL SERIES - 15PR200-SS - Stainless Steel Logo
333 people viewed this question
Top Kichler Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
