Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
My impact driver is not this model its a dc827 but it quit hammering it just free wheels if you just slightly pull the trigger is kinda works is there anything i can do to fix this prolbem?
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took my dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Posted on Jul 31, 2010
I cannot get my bar ends to move on my XJ900S Diversion
Bar ends tend to get really stuck from corrosion (rust). The best way I found, an air impact gun, much like the ones used in tire shops to remove and install the wheels on cars. A less expensive option is to get a manual or hammer driven impact driver to do the same work.
Tool 3 8 in Impact Drivers 71700
This is an example of the hammer driven tool, no endorsement implied. I have no idea what brand mine is.
The tool can be selected to turn Right or left. When you hit it with a hammer the tool is driven into the fastener (bar end) and induces a slight twist. This shock load works great for loosening tight threads.
Dec 28, 2013 | Yamaha Motorcycles
Why did my bosch ps40-2 impact driver quit working?
Brushes on the side may be worn buy new ones and change them
Nov 16, 2011 | Bosch PS40 2 10.8V Impact Driver
Milwaukee 18volt impact wrench has no power batteries are good, motor brushes seems to be ok
i have the same impact an replaced trigger switch. i think it was 38,00, had the same thing happen with my de walt xp hammer drill.U can check switch continuity before replacing
Jan 06, 2011 | Milwaukee 0879 22 V18 Impact Wrench Kit
When I bought this item it stated that you could fix sockets onto the end of Impact Driver. I am unable to see how they fit onto the end of Driver. Is there an attachment made for this purpose? Thank You...
You have to distinguish between Driver and Wrench. Driver has 1/4'' hex hole where you can insert standard bits. Wrench has a 1/2 or 3/8 Square drive and you can put sockets directly on it. Wrenches have usually higher torque compared to drivers. DC827 is driver, you might want to change it for DC822, or you can use adaptor from 1/4 to 3/8 or 1/2 Juraj
Oct 20, 2010 | Dewalt 18v Nano Cordless Impact Driver...
Only full power for full trigger pull
I had same issue with Metabo hammer drill. It was faulty triggrer. Replace it and it shoul be fine.
Juraj
Jun 04, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
Winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Feb 22, 2010 | Optics
It does nothing
Make sure that you have at least 50 psig of air pressure before you attempt to troubleshoot your impact. 70 is better, 90 is perfect. Impact wrenches are powered by internal sliding vanes, which can sometimes stick. There are a couple of ways to get it going again. Try 1 before going to 2, etc,:
1. Spray W-D 40 or a similar oil into the impact, while you are holding the trigger down. Give it a good shot. Connect the hose and pull the trigger. Tap the sides of the gun with a plastic hammer to help free up the vanes. Repeat. Normally, this is enough to get you back running.
2. Place it in a bucket and cover the gun with W-D 40. Work the anvil end and trigger to work the oil deep into the gun. Ley it soak 1 hour, and repeat the process, working the oil in, and the air out. Remove it from the oil, and drain the oil back into the bucket by holding the trigger down. Hook up the air, and blow it out.
3. Remove the cover on the head that covers the vanes. Make sure that the vanes will slide freely, and that all gaskets and "O" rings are in good condition. If you note any dry areas in the inner parts of the impact, lubricate with W-D 40, and reassemble.
4. I'm all out of ideas.. If that didn't fix it, I'd go get a new one.
Best of luck, --W/D--
Aug 13, 2009 | Air Tools & Compressors
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
189 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
