Question about Necvox RE-8169D 8 All-In-One Motorized System Car Video Player
My Necvox FD-7569 monitor has no cable/plug for the 18-way connector. Only ten of which are used, so I need to know which pins do what. (i.e. a 'Pinout' or wiring diagram). I intend to connect a reversing/cctv camera with a RCA connector to it for my car.
2 Suggested Answers
  • 3 Answers
SOURCE: Necvox Fd 7569 Headrest monitor
NTSC and PAL you is the after you press the mode, you press up/down very fast
Posted on Mar 02, 2008
Graphics dnt work tried everthing in compatibility doesnt work pls help
The problem is usually that the monitor has the wrong input selected.
If you are using VGA (The 15 pin connector, maker sure VGA or AUTO is selected in the monitor setup.
IF you are using a DVI cable, (18 pins also called a single link cable ) make sure DVI or AUTO is selected.
Many monitors will not work with a 24 pin DVI cable. (Also called a double link cable.)
The main reason is because they are not able to reach the resolutions of double link, or the graphics card is using the center 6 pins of the double link DVI cable for some other usage, which is a bad idea.
Sep 01, 2015 | Graphics Computers & Internet
Video Connection for NECVOX RE-7269
I can try finding a replacement, it will bea sier with part number
Apr 12, 2008 | Car Audio & Video
All my wires in my monitor r unhooked where they go can you tell me.
If your wires are unhooked, Usually new monitors wires are colour coded , for example, blue to blue, yellow to yellow etc.
If your wires are not colour coded, There is only one way the wires can go, They won't fit just anywhere. If they fit into one connector, then that will be where it needs to go.
Hope this helps
Mar 13, 2011 | E-Machines T2642 PC Desktop
Ribbon Cable on Necvox RE-9269D broke need replacement
You can go check at RadioShack or order the ribbon cable from EBay - http://cgi.ebay.com/HP-DV6000-DV9000-E220709-E118077-Power-Ribbon-Cable-/300393384553?pt=LH_DefaultDomain_0&hash=item45f0d74a69#ht_500wt_951
Oct 09, 2009 | Necvox RE-8169D 8 All-In-One Motorized...
What cable connects to the white ten pin connector on the aim?
DVI Digital Video Interface...you don't need it.
The 15 pin works better.
Jul 23, 2009 | Envision H190L Monitor
Hannspree tv
This is a very difficult question to answer without knowing more info, but here goes:
Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
May 12, 2008 | Hannspree HW191D LCD Monitor
Sep 22, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Necvox RE-8169D 8 All-In-One Motorized System Car Video Player Logo
288 people viewed this question
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
