Question about Refrigerators
I need to lift the door on the opening side as it has droped. model HE430TF
  • 121 Answers
The hinges usually have a few screws. The ones at the bottom can be loosened and repositioned to fit better.
Posted on Apr 21, 2008
How to remove the oven door
On many models with the door open there is a screw on either side of the door on the inside. Each screw secures the door to the hinge. Remove the screws lift the door back to the near vertical rest position and carefully lift the door out from the hinges.
Caution the door is heavy!! The door must be in the near vertical position to have the hinge in a neutral location. There is significant spring pressure on the hinges. The door should be partial open held in a neutral position before attempting to lift up.
Dec 01, 2015 | Ovens
Lights on top panel flashing temp in fridge and freezer or ok
Need more details like full model # of ref.
sound like door left open for a while check light switch make sure door is sealing when closed and light turns off door may have droped and not contacting switch for light.
Mar 03, 2015 | Hotpoint Refrigerators
Door only opens 6in
There should be 2 or 3 knobs/screws on the side to adjust torque to lift and to let down the door. Sounds like you need to increase the lift torque setting. If its maxed you can try greasing the rollers/wheels to help remove the drag. If still does not lift it then you may need a bigger motor (1hp) or you can add some springs to help lift it. Check your sensors too. Make sure they aren't being tripped at 6" up.
Apr 20, 2014 | Sears Craftsman LiftMaster Chamberlain...
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
Refrigerator side of side by side, the door will not open, no visible damage to outside of refrigerator, this is an older model refrigerator Model 52212100
There is most likely a inside shelf out of position and holding the door closed.
Remove the hinge screws from the top corner and lift the door off the bottom hinge to open it.
Check all shelves before re-attaching the door.
May 11, 2010 | Kenmore Refrigerators
Need to get the door off - model number B7425b1600E
To remove door: Open oven door fully open. On the hinge there is a small metal tag that swivels up and fits over a small hook on the hinge. Do this on both sides of hinge, then gently close oven door whilst lifting upwards- door will lift off. Reverse procedure to refit.
Mar 10, 2010 | Fisher and Paykel Ovens
Door has droped down and cant close unless you lift door back up
if you take the door off you can pack out the hinges with a fuw washers to lift the door up then it will close just fine
Jan 05, 2010 | Hotpoint HSS25GFP Side by Side...
Right side refrigerator door of side by side does not lift when opened. Part on bottom lift appears to be broken. Is it fixable.
Good day,
The cam assembly on the bottom of the door has broken.
Common problem. With the complete make, and model number, go to any appliance parts house that sells parts for your brand. They'll know what you need.
To replace, remove all food from the door. Remove the top bracket of the door, and lift the door off. Replace defective parts, and re-assemble.
Dec 13, 2009 | Refrigerators
Door on fridge side has droped 10mm the plastic washer has worn away i think .Can i get a spare please its situated at the bottom of door
Take the model number ( you didn't list it here ) to a parts house and tell them you need the door closer for the frig door . To install , remove the 3 screws holding the top door hinge located under tho top hinge cover , and lift door off bottom hinge . Remove all food items from door first . The closer should come with a lower hinge and the piece which attaches to the door . If not , tell them you need the door piece also. Or the kit may come without the hinge , but , with both the hinge piece and the door piece in the package .
Aug 09, 2009 | Refrigerators
I need a HE430TF door shelf.
Try screwing some long self-tapping screws in to hold the shelf on.
Mar 24, 2009 | Delfield Series 6000XL Remote Half Height...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
