Have a Whirlpool model WWC22 washing machine switch controller/circuit board is burned -- part no. 326001643? How much does this cost roughly?
aborcass
  • 2651 Answers
SOURCE: Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Posted on Apr 08, 2008
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
  • 53 Answers
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Posted on Oct 21, 2009
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
SOURCE: unlock control lock in washing machine, whirlpool, duet
my whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
Posted on Aug 22, 2010
My front loading whirlpool washer wont do anything but hum why? please and Thank you model wfw8300sw04
a HUM NOISE USUALLY INDICATES A MOTOR WITH BAD WINDINGS, IF UR HEARING THE NOISE FROM THE MOTOR OR BOTTOM AREA? OTHER WISE CHECK THESE
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
Washing Machine Repair Help http://www.partselect.com/Repair/Washer/Will-Not-Start
Feb 07, 2017 | Whirlpool Washing Machines
Hi ive got 2 Whirlpool wfs1071aw-7.5kg machines i changed the pump on 1 & the door sensor on the other now i have no power on either of the machines???
http://www.partselect.com/Repair/Washer/Will-Not-Start Washing Machine Repair Help
Dec 31, 2016 | Whirlpool Washing Machines
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
https://www.youtube.com/watch?v=cHpz2OcbHAY
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
https://www.youtube.com/watch?v=vskrPU9zU5M
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
parts.hotpoint.co.uk/.../washing-machines/...boards/.../C8-RIC-LVTRC-...
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares
www.espares.co.uk > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums
www.diynot.com > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ...
www.electro-tech-online.com > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
https://emwelec.co.uk/index.php?l=product_list&c=13
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
www.unifit.co.uk/washing-machine-washer-spares-parts-replacement-mo...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎
    Adwww.hotpoint.co.uk/SpareParts‎rating for hotpoint.co.uk
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎
    Adwww.hotpoint-spares.co.uk/Shop/Spares‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎
    Adwww.onepcbsolution.com/‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Have a Whirlpool Cabrio washer WTW6400SW3 went thru wash wash cycle, then started to drain water to go into rinse cycle. Half way thru draining, was a loud electrical pop in control area of washer and...
sounds like a shorted machine due to water or moister? In most case you had a fuse blow on the machine somewhat like a thermal shut off fuse, most likely located in the panel. if this is the case u need to find out what shorted it, how water or moister got in? You can also look at the control curcuit board and look for burned seized transistors or areas indicating a burned out board.
Feb 11, 2015 | Whirlpool Washing Machines
Kenmore washer model 110.21302010 lid will not lock it just clicks sensing light come on
hum lock switch may be defective test with a multimeter or the control board is not communicating with the switch check ur wire connections and the control board circuit for burns and cinges
Jan 02, 2015 | Kenmore 24032\24036 Top Load Washer
My LG front load washing machine, model WM3001HWA, has no power. What can I do?
Hello Kyle;
My name is Peter. I am a retired field service appliance technician.
You have 3 sensors in your unit, a thermal sensor, a position sensor and a door lock switch. These components will prevent you from running but, would not affect your power.
I assume you checked your circuit breaker to make sure you have power to your washing machine.
The slightest change in power supply, electrical power surge or power outage will knock out your boards. Magnetic fields and static electricity will knock out your boards. Are your appliances near a main power supply line in your home?
All appliance manufacturers recommend surge protectors if you have control boards in your appliance. Individual wall socket surge protectors cost about $20.00 at your local Home Depot or where ever. This is a good investment.
Ok, your have 3 control boards in your unit. One is the digital display board which has nothing to due with power supply.
The others are your main control board and your control panel board. Each of which can turn off power. The highest probability is the main control board. The part number for this board is EBR 44289820. The part cost $225.00 locally. You can probably get it for $180.00 if you search the internet. This is item A450 on the following link.
Remember static electricity can not out a board. Ground yourself by rubbing your hands over something that is steel. Either unplug your unit or turn the power off at your household fuse box. There are several clips holding the board in the casing. you must push outward to remove the board. Inspect the circuit back side for burn marks. If there are no burn marks you can still have a board component failure. DO NOT DISCONNECT ANY CONNECTOR PLUG IN. When you replace the board, you will replace one at a time.
Nov 23, 2014 | Washing Machines
Our whirlpool wwc22 wont start although lights are blinking. help please
the lights are blinking it won`t start to washm pls help........
Mar 21, 2010 | Whirlpool Washing Machines
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
