Question about Polaris Ranger RZR Ride on Toy
Ranger on a full charge stops working within 5 minutes. After 3 minutes or so, it runs again. Is the battery fried? Or is it overheating? It is aprox 1 year old. It is being run on flat ground. Please help
I have the same problem. My son rides his on high and when he stops, it sometimes does not want to work again for a few minutes. When he pushes the pedal, it makes a clicking sound in the gear-box area (like an electric switching sound).
Posted on Aug 05, 2010
  • 56 Answers
If power stops abruptly then theres a chance there coul be a loose connection and needs investigting. If power winds down and stopsthen yes the battery is probley fried.
Posted on Jul 18, 2010
Overheats after 5 minutes of use and stops running. Works again after about 30 minutes.
How about maybe adding coolant to the radiator till it's full. That will stop the overheating. Be sure the fan spins when it's running too, it's connected to the water pump.
Jan 15, 2018 | Cars & Trucks
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Works for a while and then stops
To rule out a fuel tank breather issue, just slacken off the filler cap so as air can enter the tank, if it carries on running replace with a new filler cap
May 14, 2012 | Garden
My trimmer only runs about 5 minutes on a fully charged battery, It seems to be overheating. If I let it cool off it will run again, but only for a short time. sometimes grass gets caught around the...
You sure the battery is fully charged. A bad battery will run a bit and then stop providing enough power. Then if you wait it will have "rested" and work another tad. Then rest again.
Almost sure that your battery is bogus.
Sep 22, 2017 | Ryobi 18v P2002 String Trimmer P2102...
Batteries fully charged. When traveling aprox. 300 feet full speed the batery indicator says the chair is out of power and slows to a crawl. after letting it rest for a few minutes the Indicator says...
Has your power chair been sitting unused for a while? It sounds like your batteries have become damaged and are having problems discharging the power smoothly or may not be taking a full charge.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of power, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own.
Oct 25, 2010 | Pride Mobility Products New Pride Mobility...
Won't charge batteries, won't run on outlet
look at bottom of ac charger check output voltage ...see wether it`s same as battery voltage..
May 15, 2010 | Samsung SC-DX103 DVD Camcorder
I have a Sansa View 8gb and the battery would die like within like 3-5 hours but when I connect it to my computer and go to properties I found that it was charged 84% what should I do about it?
What you need to do is let your player die. Then after it is dead keep turning it off and turning it on till it stops responding. This will run the player out of all battery charge. Then you will keep turning it on so that you can deplete the battery charge that your player sets up as a backup power. Then you need to plug it into your computer and let it charge all night. This will reset the player battery memory so that you can have full charge again. If this does not work your battery might be going out and you should look into either replacing it or investing into another mp3 player.
Oct 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Will not power up on AC or usb adapter
If you have an extra charger for the phone remove the end take the exposed copper wires hold them to the positive and negative post's on the battery for about 3 minutes and then plug into the normal charger.
I know this works I did it to my phone last night.
Jan 07, 2009 | Cingular Wireless 8125 Smartphone
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Polaris Ranger RZR Ride on Toy Logo
657 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
