Question about Canon Cameras
Canon EOS 30D will not operate
My Canon EOS 30D stopped wotking. It will not turn on at all. The camaera battery is fully charged. Used it at a wedding and it just quit! What shall I try?
Hey Paul
I have the same problems, I just sent it back to Canon Service Center for repairs. I will see what is the outcome.....
Posted on Jun 12, 2008
What happens when I get Error code 20 on a canon rebel eos rebel t3i 600d?
From the Canon owner's manual:
"Error codes 10, 20, 30, 40, 50, 60, 70 and 80: Shooting is not possible due to an error. Turn the camera off and on again or re-install the battery. Operate the power switch, remove and install the battery pack again, or use a Canon lens (p.32, 28)."
Jun 17, 2014 | Canon EOS 30D Digital Camera with 18-55mm...
Hello I have a 30d with a Canon 24 - 105 L series, USM, IS lenses attached. This system has given trouble free service for the past 3 years. It has done about 25,000 exposures. In the last 2 weeks it...
If you have done all that was listed in your description "normally" error 99 is an electronic malfunction however, a camera firmware update may also fix the problem. Canon has these updates on their site and it can prove beneficial in this case. One of the offices I look after had two Canon 30D's great camera and they used them hard for two and a half year and at 80,000 frames I had Canon Canada replace the shutter and shutter button which is a weak link in the electronic chain. The shutter release button gets oils from the users hands down into the circuit and causes faults as well. Most times you can see a slight build up of oils in the switch between the button and the camera body. Don't bother trying to clean it the stuff is already down inside. Try the firmware update first then if the problem is solved you are good to go if not then it's service time.
Jan 13, 2011 | Canon EOS 30D Body Only Digital Camera
My canon eos 30d turns off after taking only one picture. i have three charged batteries that i have tried, so i dont think it is the battery. any suggestions?
In your set up menu there is a function that will allow the camera to auto power off. Normally this has several setting from a few seconds to several minutes. My first thought is that this has been altered and the camera has been set to power off in a few seconds.
Dec 11, 2010 | Canon EOS 30D Body Only Digital Camera
I have a Cannon EOS 30D. There is no response whatsoever when the power switch is turned on. I have tried 2 separate fully charged batteries with no change in the problem. Can you help me? ...
There is a small Lithium coin battery on the side of the battery compartment that is the memory battery for the camera functions. Remove the battery pack first, then holding the camera with the lens facing your body look at the top back ledge of the battery compartment and see lettering CR2016. slide your finger down the back ledge and feel the ridges. with slight pressure slide the compartment up and take out the CR lithium coin battery. replace with a like new battery. If you ever need to reset a stuck program in the camera, remove this battery for a few minutes and the camera will re-boot to factory settings. This battery last for about 5 years.
Sep 19, 2010 | Canon EOS 30D Body Only Digital Camera
I want to download photos from my canon eos30d onto my mac computer but i dont have the software installed. what do i need to do/ what software do i need? Thanks
If your Mac does not have iPhoto, which is part of iLife from Apple, you can find the software from Canon USA here: 30D Eos
You will have to select the operating system on that page for the proper software
Jan 24, 2010 | Canon EOS 30D Digital Camera with 18-55mm...
EOS 30D - blue print light then dead
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom right of your computer screen or did you just yank out the cord?
Jan 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon EOS 30D camera that I got for chrsitmas and never used. I moved recently and the manual is not in the camera box. Great, I know. But the camera when I turn and try to take a picture is says...
Hi - You can download the manual from the link underlined in blue below:
Canon EOS 30D
For info on fixing error 99 see here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 15, 2008 | Canon Cameras
I have used the Canon Creative 3 program for quite some time, but now have Windows vista and it won't load. Can it be updated for that operating system/
Canon Vista compatible software now available ...with added support for some cameras, but not older ones. Go here: and navigate to your camera model and select "Drivers/Software" link. RAW Codec for Vista and updates to Zoombrowzer and DPP are available for the following: EOS-1Ds Mark II, EOS-1D Mark III, EOS-1D Mark II N, EOS-1D Mark II, EOS 5D, EOS 30D, EOS 20D, EOS 400D DIGITAL, EOS DIGITAL REBEL XTi, EOS Kiss Digital X, EOS 350D DIGITAL, EOS DIGITAL REBEL XT, EOS Kiss Digital N
May 04, 2008 | Computers & Internet
Vivitar 6000CAF for Canon EOS doesn't seem to work on my Canon 30D EOS camera?
A more appropriate product is Suntax DRF14C for Canon 10D, 30D.
Apr 01, 2008 | Vivitar 6000AF for Canon TTL Ring Light...
Canon EOS 30D SLR Will Not Turn On...
I seem to recall hearing that the power switch can be a problem on the 30D .. I'm not going to suggest you take it apart to clean the contacts .. better go to a Canon Dealer I think ..
Mar 31, 2008 | Canon EOS 30D Body Only Digital Camera
Cameras Logo
138 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
