Question about Microsoft Office Professional 2007 Full Version for PC
Whenever I set Microsoft office into my computer it works slowly. I don't know why. In the former I set it but I worked faster than that. Please be kind tell me why.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
Please uninstall your previous ms office if there otherwise reinstall your ms office and give right product key no during installation
Posted on Jul 16, 2010
I don't have any microsoft office on my computer and i want to know how to get a free download of it
Microsoft Office is a retail product that requires you to purchase a license. What you can use instead is Open Office which is completely compatible with Microsoft Office and it is free Open Office can be downloaded for free from http://www.openoffice.org/
Open Office can read and save as Microsoft Office files.
Please rate me if this works for you.
Sep 09, 2011 | Computers & Internet
Hi!! How are u? My english not good that much but i will try to explain my problem: when iam open my computerwhich work by windows xp sp3 i got massage the ip operator (3.0208.911.01) is not...
OK, sounds like the problem is that the computer cannot get a valid IP address. In fact it sounds like you might have a IP address conflict on your network. Each IP address on a network segment must be unique.
Check if you are using DHCP.
  • Go to
  • Control Panel
  • Network connections
  • Locate the network connection you are using e.g. 'Local area connection' or perhaps 'Wireless connection'
  • Right click on the relevant network connection
  • Select 'Properties'
  • Select Internet Protocol (TCP/IP)
  • Select Properties
Is your machine set to "Obtain an IP address automatically" (DHCP) or "Use the following IP address".
If its "Use the following IP address" then make sure no other machines are also using this IP address. You can try setting to 'automatic' but if you do, make sure that you note all details first, so you can revert back to the settings you currently have if you need to.
if its "Obtain an IP address automatically" then make sure no other machines have been manually set.
With regards to the microsoft update, then your best bet is to only select a small number of updates at a time, until you determine which update(s) is causing the failure. Once you know which update is the problem then you can troubleshoot the specific update.
Hope this helps
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Microsoft Computers & Internet
I deleted my Microsoft Office Activation Wizard
try this :
1. Quit all running programs.
2. Download and install the Windows Installer Cleanup Utility.
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
3. After you have installed the Windows Installer CleanUp Utility, click
Start>All Programs>Windows Install Clean Up.
4. Highlight Microsoft Office 2007 entry in the list and then click
Remove. Click OK and wait for the process to end. If any other stand alone
Office applications (such as Visio and Project) appear on the list, please
also remove them. Then, click Exit to close the Windows Installer Cleanup
utility.
5. Click Start>Run, type "regedit" (without the quotation marks) in the
Open box and press Enter.
6. Locate the registry keys below and click Delete from the Edit menu.
Click OK on the following warning dialog box.
Note: Please go to File>Export and backup all the registry first.
HKEY_CURRENT_USER\Software\Microsoft\Office
HKEY_LOCAL_MACHINE\Software\Microsoft\Office
Quit Registry Editor.
7. Delete or rename the following folders or files if they exist:
C:\Program Files\Microsoft Office
C:\Program Files\Common Files\Microsoft Shared\OFFICE12
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Excel
Data\Microsoft\Office
Data\Microsoft\Outlook
Data\Microsoft\Publisher
Data\Microsoft\Templates\Normal.dot
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Word
C:\Documents and Settings\All Users\Application Data\Microsoft\Office
C:\Program Files\OfficeUpdate12
8. Click Start>Run, type "%Temp%" (without the quotation marks) in the
Open box and press Enter. Delete all the files and folders within it. If
there are some files which cannot be deleted, just leave them alone and
this will not affect the result.
9. Empty the Recycle Bin.
10. To remove Mapi, search for and rename the following folders/files if
they exist:
C:\Windows\system32\mapi32.dll
C:\Windows\system32\mapisvc.inf
C:\Program Files\Common Files\System\Msmapi
C:\Program Files\Common Files\System\Mapi
11. Restart your computer and install Office 2007 again.
May 12, 2011 | Computers & Internet
Hi! I had just recently purschased a 2010 Compaq Mini That Needs A Product Key To Use Microsoft! I don't have WI-FI On My Computer So I need to use my dial up as i am currently using please helo me with...
preinstalled office is simply a time limited trial version and you have to buy the key to use it. on the other hand, you can download open office (www.openoffice.org) for free and that will work just as well. all you have to remember is to either set it up to save in microsoft format through the tools>options>load/save section or just choose save as and change the format to micosoft whenever you save the document. setting up the default save feature is probably best, that way you don't forget to do it.
yes, this program does work for ms docs, I use it for my ms created accounts spreadsheets and it handles them without issue.
many people won't use it because it doesn't say microsoft on the label - more fool them!
Apr 20, 2011 | Microsoft Office Computers & Internet
When trying to back date my computer through system restore, it will only let me go back 4 days. I want to go back 2 weeks. what's happening ?
Odds are you don't have a system restore point that is 2 weeks old.
System restore works based on the amount of memory you set aside for it. It continually erases former restore points to make room for new ones.
Feb 03, 2010 | Microsoft Office Word 2007 Upgrade Version...
Product key
hi there ...
try this..
Microsoft Office Enterprise 2007:
F3DJD-6FFQ4-XQTQF-PGK47-8MDQ8
Feb 23, 2009 | Microsoft Office Professional 2007 Full...
Hi. 25 character product key for microsoft office home and student edition.............I need it?
Product Key: KGFVY-7733B-8WCK9-KTG64-BC7D8, i even sent this product key to e-mailing address
Thanking you
M. Sridhar
Dec 30, 2008 | Microsoft Windows Vista Home Premium with...
Device will work faster on USB 2.0 pop-up message occurs when USB Device is plugged in
That means that the USB drive that you have on your computer is either on the USB 1.1 driver and you have to update it or your computers USB is not capable of USB 2.0 speed. First thing you need to do is find out the model number and brand of your motherboard. Then go to the manufacturers website then look at the manual for the board to find out if you have USB 1.1 or USB 2.0. If you have USB 2.0 then download the latest drivers for your board. If you only have USB 1.1 then your only options is to buy a USB 2.0 to PCI card that will give you USB 2.0 or just stay with the USB 1.1
Oct 26, 2008 | Microsoft Windows XP Professional With...
Windows 2003/2007
No, 2007 stores files in a different format than 2003 by default, however there is an option to save the files in a 2003 compatible format, so it is a catch 22 here. However, 2007 will handle all former versions of office, but the opposite is not true unless you do the options I listed above.
Mar 10, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
