Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
I have 3 mikita 18 volt le ion drills and all 3 have the same problem screws come loose and #2 and 3 speed go out is this common
    Champion:
  • 313 Answers
What the model on your tool. if the screw is the problem then locktite the screw
Posted on May 29, 2008
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
How to change brushes
on the BHP451 there are 2 screws on the back cover that need to be removed and then you can access the brushes and on the BTD 140 the same is true. The part number I see is 194427-5. If I have helped in answering your question would you please vote accordingly and thank you.
Jun 05, 2011 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Do you know if this screwgun will accept square head autofeed screws. Also can I use other bradnd screws than makita?
There is an accessory for a #2 square drive bit part number 784647-5 which you should be able to but at any store that sells Makita items. Also I would think (but am not certain) that any quality autofeed screws as long at the collation is the same should work.
May 03, 2011 | Makita BFR750 18-Volt LXT Lithium-Ion...
Lost variable speeds. Have only one speed.
Hi there
get the drill to a black and decker service centre.it is quite a common fault that can be fixed.free if still under warrenty.
Dec 21, 2010 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Both batters dead at the same time lithium ion 18 volt
sounds like your charger is faulty or both were drained & then got subjected to frost
Nov 30, 2010 | Porter Cable-Cable PCL180DK-2 18-Volt...
My new drill suddenly stopped working even though the battery has been charged OK.
Is it Nano li-ion? have you got another spare battery to double- check?
I experienced the same problem with 18V Dewalt nano li-ion battery. Was fully charged, came to work- Dead!!! I was lucky I had spare one, so then i was ok, but anyways had to buy a new one. Check on these things:
1. Battery is faulty. If u have any chances to ask someone who has the same gun (voltage is very important!!! has to be the same!!!- 12V battery to 12V gun, 14.4 to 14.4, 18 to 18 etc). Put your battery into that other gun. If You find the same problem that means your battery is dead.
2.Gun with battery contacts. If you 100% sure, that batterIES (check 2 batteries, or more) are OK, check bottom contacts where u put battery in, use WD40, or similar to clean them.
3. Least common Dewalt thing (Most common in Panasonic drills) is trigger contacts.
Basically i do not know what model is your dewalt, i was only talking in general, but there are no miracles- stopped working suddenly, and what u describe new, for instance my new drill dw727kd is less than 1 year old, i was too stuppid to open that battery myself to void warranty :(
AAAAHHH!!!!!! One more thing - If you have not tried to open these screws- check your nearest Dewalt authorised repair center- new NANO batteries have 2year warranty!
Apr 24, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Hammer drills Features
There are a few features you may want to pay attention to include: A Depth Rod mounted to the drill lets you know when the bit reaches the desired depth; Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes; Reverse can retrieve a hopelessly stuck bit; Removable Side Handles give the operator better control in normal use, and can be removed in confined spaces.
Aug 27, 2008 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
137 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
