Question about LG DLE2301 Electric Dryer
When I turn the dryer on and dial in the proper settings - the sound is gone. I also don't have any sound (music) when the dryer is finished.
  • sharon scanlon Jul 19, 2010
    Thanks so much. I had found my book and followed these exact instructions - it worked. Glad it was so simple and not some big problem. Again - thanks!
    Novelist:
  • 112 Answers
There is a button on the far middle right on the front of the unit that needs to held down for about 5 seconds.
That button will read:
"DAMP DRY BEEP"
*BEEPER ON/OFF.
Hold that button till you hear the unit respond. Now you should hear the sounds. If no sounds, you may have to reset the computer and will need to unplug the unit for 5 min and then plug it back in. You may have to hold the beeper button down to turn on the sound.
If that does not work then you will need a new display board that is right behind the front panel of the unit.
Good luck and I hope that I have helped you.
Posted on Jul 18, 2010
I have a maytag maxima dryer when I turn the dial to set cycle there is no tone sound any longer. Why not?
Hi Ann, we owned a dryer a few years ago and the kids once in a blue moon use to turn the dial the wrong way and we eventually had to buy another dial..... Good luck.
Mar 30, 2016 | Maytag Dryers
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
I CAN'T DON'T KNOW HOW TO TURN ON THE FLASH.
To turn the flash ON please follow the instructions below
  • Raise the Flash
  • After pressing the tinualbinale_1.gif button turn the mode dial button tinualbinale_20.jpgon top to choose tinualbinale_16.jpgsymbol.
  • Then press the FUNC.SET tinualbinale_17.jpg button.
  • Once set, tinualbinale_18.jpg symbol will appear. Now the flash is turned on.
Jun 04, 2011 | Canon PowerShot SX130 IS Digital Camera
I push the button to dry my clothes and it is still damp. The dial has a 30 minute side on each side. It is a new machine. I'm used to setting the dial one time and my clothes are dry.
Make sure you don't have the vent kinked or stopped up with lint. Sounds like your dryer may be overheating. The vent connects to the back of the dryer and pipes to the outdoors.
Apr 13, 2011 | Dryers
Gas Dryer is not heating. Setting dial is not clicking in as you turn the dial to different settings. Model GLGQ642CAS2 Can you replace the dial? Is it worth it? Can this dryer be retro fitted for the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Frigidaire Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LER5636P Electric Dryer
Here's the problem: There is a dial on the dryer that should allow me to adjust for 'more dry' and 'less dry'. Up until recently, I could set the dial, and end up with clothes that were either 'more dry'...
sounds like you may have a clogged or kinked vent. its generating heat so the dryers good, your not exhausting properly, either clean or replace your venting, look to where it exits hte home sometimes theres ascreen over it cloggged with lint!!!!
Mar 17, 2008 | Dryers
LG DLE2301 Electric Dryer Logo
243 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
