Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
Trying to hook up a Linksys E1000 with a Motorola modem ( optimum ) on a new laptop and a desk top and at the end the router can't be found by either one. Any solutions?
  • dhagopian119 Jul 16, 2010
    Trying to connect a Linksys E1000 router with a Motorola modem from a laptop and a desktop, neither one can see the router, how can I make this work, ( I'm NOT a technician )
  • 4,889 Answers
You should first make a wired connection to the router and ensure that the wireless feature is enabled? Did you check this? Also most desktops do not come with a wlan card by default you should either obtain a WLAN card or a USB wireless adapter if you wanna connect it to wireless network.
Posted on Jul 16, 2010
  • 18 more comments
    My laptop is 6 months old and I was told it has wireless capabilities built in, this set up is to be used in same location as the router, do I need to activate this capability?
  • eagle338
    eagle338 Jul 16, 2010
    You need to configure the router. First try to turn on the wireless switch on the laptop. Let me know the make and model of the laptop and I will help you do this. Also it was not the laptop I was talking about, its the desktop that does not have wireless capability.
    Thank you, I just installed a netgear wireless adapter on the desktop, hopefully that will work, but if you could tell me how switch the wireless switch on the lap top I would appreciate it
    The lap top is a Toshiba Satellite L505D-S5965
  • eagle338
    I will surely help you with that if you can get me the make and model of the laptop.
  • eagle338
    Press Fn+F8 to enable/disable the wi-fi. See if can find the network. If problem persists we will check for wireless driver problems and whether wireless is enabled on your router.
    Sorry I lost connection, my laptop has the wireless switch on and does not see the internet
  • eagle338
    Ok. Do you have LAN cable so that you can connect to the router using it and enable wireless?
    yes but the laptop doesn't see the internet ( optimum )
  • eagle338
    Its enabled on the laptop. I am talking about the router. On the router there will be an option to enable wifi. Just wanna make sure that it is enabled.
    I don't know which button does this on the router, there is no documentation
  • eagle338
    Its not a button. You have to enter the router configuration mode to do this. I can help you do it provided you have a lan cable that you can use to connect to the router.
    I have the cable
  • eagle338
    Ok. Connect the cable to the router then connect it to the router Type in 192.168.1.1 into your browser's address bar and hit enter. Leave the user name field blank and type in your password. Hit enter. Click on the option that says wireless and see if you can find an option to enable it. Otherwise just get me the screen shot with the configuration utility open and I will help you deal with this.
    connect the router to the router?? Please tell me how the connections go, Modem-Router-PC I'm confused
  • eagle338
    Sorry I meant modem-router-pc
    I didn't even know there is a password, thanks for your efforts, this is too slow, I think that I piad for this and I'm not happy
  • eagle338
    Everything is not simple my friend. More so considering your apparent lack of experience. I am trying to help you the best way I could. Here in fixya it is illegal to use remote support. Otherwise I would have configured it for you myself.
    I know that everything is not easy, I was told this all was plug and play. I guess I should apologize for my lack of experience, you have interesting customer service skills, good thing you're not in sales
  • eagle338
    Thank you. Appreciate it :).
    Genius:
  • 1,354 Answers
Hi
you traing at time 2 modems chack IP of Motrola and linksys if you want to using linksys then just configure you local setting on linksys
it has a both 2gethe modem and router
try linksys alone with your DSL line
  • Configure the Router
    1. Step 1
    Open your web browser, type "http://192.168.1.1/ " into the address bar and hit "Enter."
    2. Step 2
    Use "Admin" as the username in the pop-up box and leave the password blank.
    3. Step 3
    Connect to the Internet and click on "Internet Setup."
    4. Step 4
    Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
    5. Step 5
    Set a service set identifier (SSID) to identify the router and change the password.
    6. Step 6
    Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
For beginners-how do i connect the linksys e1000 to my hughes net modem? or do I hook the cable directly to my tower so i can use my laptop in another room
The modem will plug into the router, it should come with a cable for this, there will be 5 ports on the router, one will be labeled as internet most likely , this is the one you use, the other 4 will be numbered and you can use any of these to connect your tower. the wireless should work automaticly for your laptop, but if you want to make it a secure network, please contact me directly and ill walk you through it.
hope this was helpful
Jun 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have internet service with Washington broadband in Yakima, WA. Trying to hook up Linksys E1000 router is proving to be difficult....all hooks up fine, but router not recognizing internet...
you may want to make sure that your IPS supports DHCP or you connect using a dynamic IP address. If not supporting DHCP, you want want to login into router to reconfigure it. Here is link for more info. http://www.linksysbycisco.com/EU/en/products/E1000 I have seen similar issues many time. Good luck and let me know.
Thanks
Apr 09, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I just bought my new Cisco Linksys E1000 WirelessN Broadband router, set up the brand new cat 5 wires and hooked it to my modem. My old lap top is able to see the wireless network but my alienware lap top...
if you're running windows 7 sometimes it tries to auto detect the type of network but doesn't ask for a password, when it starts to try to auto detect hit cancel and enter in the password manually.
Dec 31, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
How do I hook up my linksys to my desk top pc (XP) so I can run my lap top from upstairs
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Nov 07, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
through the modem.
modem
Then you need to connect the computer to the
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
I have an old Linksys WRT54G v1.1 wireless router - trying to connect to my new DSL line using a motoral modem, to my Dell laptop running XP. help!!!
Is the motorola currently surfing and are you trying to add the linksys to it? If so you will need to go into the motorola and set it to bridge connection under connection type found in the expert mode of the modem. Then you will add the linksys and input the username and password in the pppoe connection type. Once the info is save click on the status tab and click connect. Hope this helps
May 16, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
How do i connect and get signal?
This is a common problem with Linksys wireless routers and primarily the WRT54G and WRT54GS. For some odd reason they all of a sudden go stupid and forgetful.
The easiest method to revive these routers is to go to the Linksys web site and get the automatic configuration download for your specific model of wireless router.
Hope this helps you
Dec 26, 2008 | Linksys Wireless-G WRT54GS Router...
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
248 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
