Question about HP PSC 1510 All-In-One InkJet Printer
Printer keeps taking paper crooked
The glass on the scanner part of the printer broke, and so maybe it is caused by shards that have gotten in the way?
The "check paper" light keeps coming on when I try to do a test run, because the paper is going in crooked. any suggestions?
  • 62 Answers
On the ADF?
which glass is broken? the platen glass or the slitter glass.
If the paper is going in crooked it means that the papaer is getting stuck where the obstruction is
Posted on May 11, 2008
Paper jam in printer keeps coming up we have cleared all paper out and it still comes up. Can you help?
use a bright light (LED flashlight, for example) and examine all nooks and crannies in the paper path to find that one tiny shard that is causing the jam indication (or blocking the detector). You may find it necessary to use tweezers to remove the paper bit by bit.
May 04, 2016 | Office Equipment & Supplies
Do you have take apart istructions for an HP Designjet T790
  1. Take the first paper clip and contact the lower two brass rectangles, this fools the device into believing the duplexer is installed, keep the contacts bridged (don't remove your hand or the paper clip until Step 4.) There's no electrocution risk.
  2. Press the "OK" button on the control panel to pretend the paper jam is cleared.
  3. Carefully observe the pair of white gears on the left, if they seem to clutch, stall, skip or freeze then you have paper shards which are causing the jam.
  4. Using a firmer grip or pliers, grip the furthest left rubber roller and rotate in either direction , the gears should rotate with your efforts and look for shards of paper in the gear teeth.
  5. Use the paper clip, toothpick or any appropriate edged tool to clear the shards.
I share a informative links please visit and follow instruction i hope solved your issues.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00441807
Thanks,
HP Printer Support
Jun 23, 2014 | HP Designjet T610 InkJet Printer
Brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Sep 04, 2009 | Brother MultiFunction Center MFC-440CN...
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Paper jams 1/2 way through drum/cartridge. Jams like an accordian, with 1/2 page printed. My printer is a Brother mfc 7420. About 2 years old.
Take the toner cartrige out, look around with a flashlight for a piece of paper or something that could jam the works. Check the movable tab that comes out of the front of the machine to hold paper up, maybe it has gotten crooked or something. Don't have anything in front of the machine to block the paper coming out. A can of compressed air can be used to blow the machine out.
Apr 12, 2009 | Brother MFC 7420 All-In-One Laser Printer
My printer will not completely roll paper through the printer
Maybe the cartridges are in slightly crooked. Take them out and put them back in. Make sure there is no paper or any other obstruction around there and try again. :)
Mar 05, 2009 | Lexmark X2500 All-In-One Printer
Automatic paper feed
The narrow glass section at the left of the flat bed scanner glass is shaped concave to route the paper back up to the tray if you are using the document feeder. Right above this is a spring loaded paper guide that puts slight pressure on the paper as it is fed through. If the cover of the scanner is not closing completely it will miss guide the paper. I would check that there is nothing on the flatbed or in the hinge section that is keeping the cover lifted slightly. The hinges do extend for copying books, so it may have jammed in the up position causing your problem. Good luck!
Sep 08, 2008 | Brother MFC-8840D All-In-One Laser Printer
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
Paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Apr 17, 2008 | Konica Minolta bizhub C250 All-In-One...
HP PSC 1510 All-In-One InkJet Printer Logo
111 people viewed this question
Ben Johnson
