Question about Samsung RB215LASH
Samsung Ice Maker on Mdl RB215LASH
Ice Maker was turned off for about 8 weeks and was working when we turned off. Turned back on and ice tray has not filled , checked water supply input into their pipe and water is their. how do I trouble this problem I have a Mdl RB2155BB and left the icemaker off for about 6 weeks.  The solution to press the restart button caused the tray to dump, but did not refill.  My refrig has a special water supply tube (you can recognize it by the braided stainless steel looking exterior)  that has an automatic shutoff if there is a leak.  I reset this tube by disconnecting it from the valve and then reconnecting it.  Tried another ice maker reset and got water plus several pieces of ice. One more reset and all was fine. It seems that for this model Samsung, I would not recommend shutting the ice maker off for more than 3 weeks. Refrigerator purchased 2/18/08. I didn't have a water line in place at the time so I left the ice maker turned off. After installing the water line on 4/19/08 I turned the ice maker on but absolutely nothing has happened after 2 days.
  • fixy6592 Jul 22, 2008
    I had the same problem. The ice maker was working great. I had turned it on and off several times during the past year and it never had a problem. The last time I turned it off for a couple of days and when I turned it back on, it wouldn't dump automatically again. I have pressed the reset button on the ice maker and it dumps and fills fine. But it won't dump again without the manual button being pressed.
    Any ideas?
  • Anonymous Mar 16, 2014
    water overflowing in ice maker
I also used a hair dyer and thawed the line behine the ice maker. Pushed the reset button and ice came out of the line into the tray. Pushed again and water filled the tray. It is now working, but for how long.
Posted on Dec 19, 2008
  • 725 Answers
Make sure your feezer is below 5 degrees F .. or it will not make ice.. hope it helps
Posted on Jun 12, 2008
  • 121 Answers
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
  • Timothy Brooks
    Timothy Brooks Apr 21, 2008
    Any chance you would give more clues?
2 Suggested Answers
SOURCE: Samsung Ice Maker on Mdl RB215LASH
ice maker fill line frozen up
Posted on Apr 07, 2008
Ice not falling out of ice tray. Why?
Is water going to ice maker? Is itaking ice at all
Apr 16, 2015 | Samsung RB215LASH
Water not getting to icemaker
This may be a temperature sensor problem on the ice maker. Check for broken wires or sensor fallen off.
Mar 24, 2013 | Samsung RB215LASH
Samsung RB215LASH freezer not cooling ice maker stopped working
Do you see any ice buildup on the back wall of the freezer?
Oct 18, 2012 | Samsung RB215LASH
Hello, I have an Samsung rs2533sw. the ice maker stopped working. it is at 8 degree. at this juncture, the manual reset switch does not work. if I let it unthaw then it works. once it gets cold it doesn't...
Hey heads up! The ice-cube maker has two parts... In fancy terms the business motor end, and the back-stop. Your back-stop is all busted. Mostly because it's been used successfully as a backstop for a few thousand times. The piece costs about $20, and you can get it at any Samsung parts distributor. The best way to check this is that your ice-cube tray will look like it's coming un-hinged in the back when it attempts to empty the ice.
When it works properly the ice-cube tray is actually contorted about 45 degrees from the front end to the back. The same way an adult male would crush ice.
Oct 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung ice maker tray won't reset
I had the same problem and would "temporarily" fix it by opening the front plastic cover (remove the 4 screws) and CAREFULLY remove the front - sometimes all the plastic gears will fly off but you can get them back because they only fit one way. Once the gears are off, you can reset the tray back to its fill position. Fit the gears back into place. Replace the front cover and it worked like a champ for a couple of weeks when I'd have to do it all over again. I finally got tired of it and ordered a new unit through ebay. Easy to replace BUT now the water won't come on to fill the tray!!!! UGH Hope this helps
Sep 21, 2009 | Samsung RB215LASH
Ice maker stopped working. Turned it off as there's no way I need a bin full off ice. I also don't use a lot of ice. Ice was "getting old" so I dumped it, cleaned the bin, turned the button on and nothing....
The freezer temp needs to be around 0 degrees for that "something" to click to tell it to dump and make more ice. Check the freezer temp and adjust if needed. If a thermometer says it's cold enough you may need that warranty you mentioned.
Jun 25, 2009 | Samsung RB215LASH
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
the electric motor for the ice-maker is not turning...why? try disassembling and power motor with 115VAC cord from wall plug...be careful-ensure frig unplugged...using alligator clips...does it turn...can you hear it...it should turn VERY slowly.
May 27, 2007 | Samsung RS2534 Side by Side Refrigerator
Samsung RB215LASH Logo
1,114 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
