Question about Acer Veriton X480G 320GB PSV9703004 PC Desktop
Have increased ram on my Veriton x480g adding 2 GB but now at start up get a page telling me that computer has been opened and I need to press F1 to start. how can I remove this.
  • Acer Master
  • 32,281 Answers
In the BIOS configuration there is a setting to detect the case if the has been opened. Reset this setting, then save and exit
Posted on Jul 16, 2010
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
How do I turn on Wifi on my Acer Veriton N282G?
Depending on your operating system, there should be a stack of curved bars.* Click on that, then click on an available network.*
images:
May 16, 2014 | Acer VERITON N282G PERSONAL COMPUTER ATOM...
My Acer Veriton X480 turns off after few seconds and won't boot.
Have you cleaned it lately? Is it getting sufficent air flow? A few cans of compressed air and a can of Electronic Contact Cleaner spray. If so, I would suggest the PSU may be bad. Reseat the memory mods, Try to reboot. If it starts, LED's blink, then completely powers off, Test the PSU with a multimeter, replace if necessary. Do you get anything on the monitor? Or does it shut down before? Had you done any hardware or software updates/upgrades?
Jan 10, 2013 | Acer Veriton X480G 320GB PSV9703004 PC...
I have a DELL with XP-Home Edition - version 2002 service pack 3, Intel(R) - Pentium(R) 4cpu 2.66ghz, 2.66ghz, 512 MB of RAM My daughter plays games and has 24 of them in the computer - she tells me I...
Hello, Jim.
Dell's official position is that the maximum memory for this PC is 1 GB. But, it may be able to support 2 GB, per Intel's specs.
But, to answer your question - yes - you can increase your memory amount to 1 GB. Since the system has 2 memory slots, you could conceivably have (2) 512KB modules (total 1 GB). If your system already has 1 module of 512 KB, you could add another. Just be certain it's the same type and speed.
Or, you could have a 1 GB module.
I don't think that your computer's life is in jeopardy, but additional memory always helps the speed of your computer.
Hope this helps.
Sep 19, 2010 | Dell Dimension 2400 PC Desktop
I need to replace the 512 Ram Memory card with 2 new 1 gb cards
Yes that's correct simply turn off the power OFF from the computer and to make sure unplug it from the power outlet, then remove the existing 512 RAM and put the new RAM and then turn the power back ON and that's it.....
Apr 03, 2009 | Dell Dimension 2400 PC Desktop
Increase graphics card memory
go to your bios setting > chipset feature > onchip AGP.
you can increase your Graphic card from ther if it is on bourd.
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
RAM installation
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Jan 14, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
I want to add additional RAM to my Veriton 1000 PC where can I find a HowTo or Installation Guide ?
Here is the memory information on your system:
http://www.crucial.com/store/listparts.aspx?model=Veriton%201000
A total of 2 slots each capable of a 1 GB RAM module
Here is the user guide for the system:
http://www.acerpanam.com/synapse/data/7117/documents/VT1000_UG_ENG.pdf
Adding RAM is simple. Unplug all cables from the tower, then press and hold the power button on the front of the tower to release any stored power.
It appears that 1 screw holds the side panel on (it is on the back) and then removed the side panel. This should give you access to the RAM slots on the motherboard.
May 14, 2008 | Computers & Internet
Acer Veriton X480G 320GB  PSV9703004 PC Desktop Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
