Question about Epson Office Equipment & Supplies
For some reason, my Epson scanner will not scan.I have checked all connections and they are fine. When I press the button to scan, notthing happens. I used thr printer this morning and it mis working fine. Am I missing something ?
  • fgleaso1 Jul 16, 2010
    I asked where do I find documents concering my scanner ?
    My Epsom printer is NX110
  • 2,069 Answers
Have you tried scanning from the computer application... If you are running windows, try and initiate the scan using the windows Document imaging software that comes within the office package. post back for a followup.
Regards
Posted on Jul 16, 2010
  • 2 more comments
    Where do I find Windows documents ?
    Where do I find documents pertaing to my scanner ?
  • Muzahura Frank Jul 16, 2010
    Do you have microsoft office installed? two, what is your epson model?
    please download and install the scanner utility for windows from here
  • Epson Master
  • 4,737 Answers
Well, let try like this, remove all the cartridges, clean the contact points on the cartridges and on the printer using a piece of cotton of soft brush dipped in alcohol/acetone/spirt. Turn off the printer, disconnect all the cables, leave it off while you do some cleaning. Remove the Paper Jam door and clean the passage.
Again plug in the power cord, and switch on the Machine. Keep pressing the power button while it powers up. Leave it On for few minutes and install the cartridges, now try scanning a document and check if it behaves normally or if you can hear anything unfamiliar.
Let me know if this isn't successful.
Good luck.
Thanks for using FixYa.
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Press the scanner button & nothing happens
check for conflicts in the computers device manager if your using windows as an operating system, install and reinstall the driver. make sure you only install epson scan...you can download the latest driver in the website www.epson.com
Oct 15, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Unable to open Epson Scan in 4490
try to uninstall and reinstall your printer software
Jul 17, 2009 | Epson Perfection 4490 Film / Flatbed...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Nothing happens when i hit the scan button on my epson cx5400
you need the proper driver for the scanner which is compatible with your operating system.
what is the full version of your operating system?
You can download the twain driver off the support.epson.com site.
if you need more assistance please let me know.
May 12, 2009 | Epson Stylus CX5400 All-In-One InkJet...
EPSON Scanner 4490 Problem
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
EPSON V700 Photo Scanner
Unplug the power supply from the power port on the scanner then plug it back in after a few seconds and power-up if it isn't already on. This happens to me a lot and this works every time. Frustrating though.
Jan 14, 2008 | Epson Perfection V700 PHOTO Flatbed...
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
