Question about Horizon T92 - Treadmill
What lubricant can be used on the Horizon T92 Treadmill
    New Friend:
  • 69 Answers
    President:
  • Horizon Master
  • 832 Answers
Go to www.horizonfitness.com then click on e-store then look for part and accessories the silicon lubricant to purchase. Follow this procedure before applying lubricant.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components.
2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
Posted on Jul 16, 2010
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
How to calibrate speed on t92
1) Under the hood lift and see the instruction for use the software calibration, and follow the steps, and proceed.
2) This will guide you to diagnostic, and fix it various problem to factory settings.
sincerely. Happy New Year . G-d bless you.
ernesto cuaddra
managua, nicaragua. c.a
Dec 27, 2011 | Horizon T92 Treadmill
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
What does it mean when it sayd lube belt?
I have treadmill. show indicator lube belt . what that'smean
Dec 21, 2010 | Horizon T92 - Treadmill
Motor wont staret up
Does the console power up? Will elevation work? All console keys appear to work? Smell anything before tread died?
Oct 17, 2010 | Horizon T92 - Treadmill
Display says LUBE
It is time to lubricate the running belt you may purchase this lubricant at your fitness specialty store or directly for Horizon their # is 1-800-244-4192. Here is a procedure you can follow and your owners manual should have the reset procedure after completing lubrication procedure, if not while ordering the lubricant ask Horizon for it.
LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes.
Mar 13, 2010 | Horizon Exercise & Fitness
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Horizon T92 - Treadmill Logo
403 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
ray gallant
Tom Chichester
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
