Question about Acer X1261 DLP PROJ SXGA 37001 Multimedia Projector Projector
Brought an Acer x1261 projector and have trouble trying to play set top box (tv) and dvd at same time, only has s-video and video port. Can connect one or the other, but not play both.
  • 144 Answers
Unfortunatly this can not be functioned,
the product unfortunatly does'nt surport this.
Posted on Jul 16, 2010
How do you connect your projector to your TV. It's a mitsubishi projector
Usually through a Video output on the tv, best connection would be from a set top box, DVD player or satellite/cable box to the projector. That way you'll get the best picture available
Oct 07, 2014 | Office Equipment & Supplies
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
May 25, 2014 | Office Equipment & Supplies
Does anyone know the part number for DMD chip in Acer X1260 projector?
Hello i got issue with white and black dots on ACER X1260.
The orignal parts was a 1079-6319W...
I tryed to put on a 1079-6329W supposed to be compatible.
I got white vertical lines on screen and no more pixel dead, this reference seems not compatible ( i think its 18W->19W ; 28W ->29W only).
I tryed to clean up with KF special contact F2, chip pins, socket, cards connectors, but nothing worked, still vertical white lines with 1079-6329W chip ( instead of 1079-6319W).
I hope this can help everyone in trouble with Acer X1260 and other.
DMD chips are not so compatible !!!
Sep 07, 2013 | Acer X1261 DLP PROJ SXGA 37001 Multimedia...
Acer DLP X1261 has specks all over image. How can I clean it. It seems to be back of the lens.
I just pulled my apart and cleaned all 3 internal lenses and color wheel, totally the same after cleaning, even though you can see heaps of dust in lens I believe the problem is in the DMD chip, I have some on order from alibaba.com and will see if that fixes them, I have. 2 acer x1260 that have both turned approx 10 and 50 dead pixels each
May 18, 2012 | Acer X1261 DLP PROJ SXGA 37001 Multimedia...
I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Jan 12, 2012 | Denon Audio Players & Recorders
Ho do i connect my laptop to my flat screen samsung tv
There are 3 ways ways to do this from the left side of the laptop.
1) S-Video-out jack [Connects an optional S-Video device such as a television, VCR, camcorder, overhead projector, or video capture card.]
2) External monitor port [Connects an external VGA monitor or projector.]
3) HDMI port (select models only) [Connects an optional video or audio device such as a high definition television, set-top box, DVD player, or any compatible digital or audio component.]
Your TV will have one of those interfaces. You just need to look at your user manuals for both the Laptop and TV
Take Care
Oct 03, 2010 | HP Pavilion dv9000z Notebook
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
Acer X1261 DLP PROJ SXGA 37001 Multimedia Projector Projector Logo
153 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
