Question about iRiver E10 Digital Media Player
Emergency usb mode
Black screen saying player update required... please refer to the manual, or emergency usb, bottom right corner - v1.40.Not responding to any buttons.
  • 6 more comments
  • skalar Apr 21, 2008
    Given that the device is not rsponded on any button, the only way to turn it off is to remove the build-in battery. Should I do this?
    Yes, I have tried to connect to usb but the device was not recognized by my PC as a separate external drive. I also have tried to initialize the device by following the manual's recommendation but got an error msg stated that initializing is faled.
    Please advice further...
    Thanks.
    Thank you for the possible error reasons (pos. 1, 2).
    If you have any other professional recommendations rather than to return the device to the manufacture with the potential prospective to wait for 3 + months - you'll be highly appreciated.
    I have unplugged the battery and after 45 min plugged it back. Unfortunately, I got the same picture: device icon on the display and then black screen saying player update required... please refer to the manual, Emergency usb, bottom right corner - v1.40.Not responding to any buttons.
    Please advice.
    Thank you.
    1. I bought this iriver e10 3 months ago, load some music and all this period of time the device did work perfectly. Before getting this error the device was not in use during ~ 10 days.
    2. Sure, I have tried to reset but every time, when I pressing the reset button, the device icon is appeared on the display, and then black screen saying "Player update required... Please refer to the manual" or "Emergency USB", bottom right corner - "v1.40". Device is not responding to any buttons.
    3. Attempts to initialize the device according to the manual's recommendation (via iriver plus 2) and unplugging the build-in battery for 45 min were also not successful.
    I have made it a few times but it still does not work.
    A couple of times the device has been recognized by my PC as a removable disk, I even was able to see the properties and driver for the device but it is not responded when I was trying to browse it. All time I see the black display with 'Emergency USB' and 'v1.40'.
    Looks like the device is dead.
    Thank you for your attempts to resolve my issue.
  • skalar Apr 22, 2008
    Yes, please.
    Thanks.
    Brooklyn, NY 11224
  • 123 Answers
There are 2 conditions related to the e10 Emergency USB message.
1. If your PC does NOT recognise the iriver as a USB device, there is an issue with the Hard Drive.
2. If your PC DOES recognise the iriver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
In either case, your iriver needs to be returned to the manufacturer. If it's under warranty you can get this repaired at no cost (of course). This is a very common problem with these players. I hope your is still under warranty and you can get it repaired. Some people are saying they have been waiting for 3 months and iRiver still hasn't sent them there replacement.
Good Luck
Posted on Apr 21, 2008
  • Amber Engman Apr 21, 2008
    Sorry i couldn't help more.
    Depending on where you are you might be able to get it fixed really quickly.
    Since it's only 3 months old, i would let them repair it for sure.
    Good Luck.
    Master:
    Sergeant:
  • 461 Answers
Try to reset...as below
1. tunr it off
2. remove any power supply to the device including any battery.
3. leave it for about 30 minutes
4, tyrb ut ib again
  • 3,037 Answers
Have you tried connecting the usb and loading an update on it at all?
Let me know if you have or if trying that doesn't work and if it doesn't then I will provide further help based on the situation
Thank you for using Fixya and Good Luck
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri Apr 21, 2008
    Yes, remove the battery, it should not harm the device and will most likely reset it and you should be able to be on your way and load the updates and have it fixed.
    Please let me know if this doesn't work or if you need any further help
    Please don't forget to rate this solution once your problem is fixed
  • Benjamin Patri
    What were you doing before getting this error? Possibly loading something?
    Should should try to press the reset button which is located right below the lock
  • Benjamin Patri
    Try loading a new update on it again.
    Have your computer off and battery removed from the player
    Connect them together and put the battery in and turn it on and then turn on the computer and see if the computer recognizes the device and see if you can load a new update onto it.
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    Do you need help locating a service center at all since we couldn't do much more?
  • Benjamin Patri
    Can you give me your zip code then please or city and state, thank you
  • Benjamin Patri
    Alright here is the deal, IRiver does not have a location in New York, your best bet is to see if an electronics store like Best Buy, Circuit City, or Radio Shack can fix it or you can try sending it to the manufacturer if the above stores won't service it. So my advice is to call the above stores and any others that you know of in your area (I can find phone numbers but I think you can find them pretty quickly in the phone book otherwise) or I can get you the number for the manufacturer who should be able to fix it but then you will have to send it in for sure. Let me know what you want to do and I will help with what I can. Thank you
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
Lg phone shows time and date but will only make emergency calls. says to retry
Download and install lg phone drivers and the LG updater.
Now connect the phone to PC with a USB cable.
And launch the LG updater. This will fix your problem.
If not let me know. I'll give a next solution.
Cheers...!!!
Nov 29, 2012 | LG Quantum Smartphone AT&T C900 Windows 7...
Wet phone
u must quickly remove its battery and go to a near by cellphone mechanic or to the service centre
May 05, 2008 | Samsung SGH-E370 Cellular Phone
Emergency USB and v1.40 ??????
  1. my mp34 does not want to wark
  2. i do not know how it charge
Dec 22, 2007 | iRiver E10 Digital Media Player
E10 Problem
You need to upgrade the firmware by using iriver plus 3 in the 'tools' section it should have upgrade firmware.
Nov 13, 2007 | iRiver E10 Digital Media Player
IRiver H10
Sounds like you either have a bad hard drive or some of the song files are corrupted.Have you gone into the "Emergency Connection" mode to reformat the player? Rest the player; if it's a 20gb stick a paper clip in the reset hole, on a 5 or 6gb remove and replace the battery. Then connect the player to the PC. Hold the enter button down when you turn it on, it should come on and read "emergency connection" at the top within a black band.
You must go to the iriver.com web site and download the firmware updater for your player. Her is the link; http://www.iriveramerica.com/support/hd/. Then select either the 5-6 or 20gb firmware. Run the firmware program while the player is in the "Emergency Connection" mode. You can also get the firmware upgrade info from iriver. That should solve your problems and in addition you will be getting the latest firmware.
Sep 18, 2007 | iRiver H10 MP3 Player
IRiver E10 - Error screen - Emergency USB
Hi There,
1. If your PC does NOT recognise the iriver as a USB device/drive, there is an issue with the Hard Drive.
In either case, your iriver needs to be returned to the manufacturer. If in warranty you can get this repaired at no cost (of course).
Sep 06, 2007 | iRiver E10 Digital Media Player
IRiver E10 Player update required
I took mine to JB Hi-Fi where I bought it from and they're sending it to the service centre for me ... if your 1 year standard warranty hasn't expired you can take it to the place you bought it from and they can ship it off for you and they log all your details and give you a number so you can call and check the status of the repairs ... that's the only thing that will solve the problem as far as I'm aware ... they need to actually replace parts in the iriver ...
Aug 21, 2007 | iRiver E10 Digital Media Player
Missing system files
how reinstall the firmware for E10? the laptop doesnt see the HD of E10.
Mar 16, 2006 | iRiver H10 MP3 Player
iRiver E10 Digital Media Player Logo
314 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
