Question about HP PSC 1610 All-In-One InkJet Printer
The last time I used the printer, 18 hours ago, there was no problem. Next time I went to print, I got the error message to remove and check the right cartridge. I did so at least 8 times.. message remained the same. I rebooted, message stayed the same, I unplugged the printer, replugged, message stayed the same. Since this started, I'm also unable to close down the printer. It says it's closing down, then stalls out. Up until now, this has been a great little workhorse. What can be done to fix this issue? Thanks in advance.
  • mail_dumpp Jul 16, 2010
    I so appreciate the help I was given. I really thought my printer was a gonner....never considered it could be a faulty cartridge.
  • 2,069 Answers
Partial reset by doing the following: Press and hold Cancel and the Left Arrow while plugging in the power cord. If that doesn't solve the problem and you are absolutely sure that your cartridges are good, then it's repair or replacement time
Posted on Jul 16, 2010
  • 2 more comments
  • Muzahura Frank Jul 16, 2010
    looks like that printer has damaged its own catridge and you may have to replace it.. that is if my above solution has not worked. but before you replace it, you need to download a patch (HpPsc1600_Uni_FwPatch2.exe) from
    hp-homepage first, connect your printer (with the destroyed cartridge in
    it) and install the update of the All-In-One software. Then you can
    install a new cartridge.
    Regards
    Neither worked. I'm sending a print screen showing the patch info.
    akk.... the pic is small. The patch info given was for the 1600 printer, mine is a 1610, so the patch didn't work.
    I installed a new cartridge and all is well ! Thanks for your help.
Paper Jame when i start printer after 10 to 12 houres and hang after three or four time restart printer then print the paper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 10, 2010 | HP LaserJet 1100 Printer
Printer not printing
When this error appears in your printer check if ink are smeared on the holder where the contact panel is with the cartridge. To fix this issue use the Kleenex (perfume ) added with few drops of water to dampen it and clean off those contact on the holder. You should let the unit sit 24 hours for best results. Before printing anything run aligned the cartridges a couple times then run clean cartridges a couple of times. Print the test page to look for the condition.
Thank you !!
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
Unable to carry out print command
Issue : Desk jet 5150 Not printing
Environment :
OS - Not provided
Printer : Deskjet 5150
Solution :
There could be 2 reasons for your problem
check the following links
Solution 1 fig are available
Step 1: Press the Resume button
Press the Resume button. Wait for approximately one minute and then print a self-test by pressing and holding the Power button and pressing the Resume button four times. Release the Power button. The self-test page should print. If the carriage is still stuck, go to the next step.
Step 2: Power cycle the printer
Turn the power off and back on, following these instructions:
1. Turn off the printer by pressing and releasing the Power button. If it will not turn off, proceed to Step 3. If it does turn off, proceed to the next step.
2. Turn on the printer.
3. If the Power light is on steady, print a self test with the instructions above in Step 1.
Step 3: Clear the paper path
Reset the printer and clear the paper path of any paper that may be jammed in it, using the following instructions:
1. Leave the printer turned on and disconnect the power cable and the USB or parallel cable from the back of the printer. Do not reconnect them until instructed later.
2. Remove the paper from the in-tray.
3. Remove the rear access door or duplexer (if installed) from the back of the printer.
Figure 4: Removing the rear access door
4. Open the top cover of the printer.
5. Check for and remove any paper still in the printer. A paper jam could cause the error message and the carriage stall.
6. Replace the rear access door, close the top cover, and replace the paper in the in-tray.
7. Reconnect only the power cable. If the printer does not automatically turn on, turn it on with the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, do an internal test as described in Step 1 above.
If the carriage is still in a stalled position, contact HP Technical support to have the printer serviced.
IntroductionWhen printing with a HP Deskjet printer on Windows XP, the user may get the following error messages:
  • Error with USB
  • Out of paper message
  • Error lost communication with printer
  • Any other error messages related to communication.
The following performance failures could also be observed:
  • Partial page is printed, then ejects incomplete.
  • Blank page is ejected with nothing printed on it.
InstructionsThe error may be either a hardware or software issue. Firstly, make sure that all connections between the printer and PC are secure. Secondly, check if the printer can perform an internal test. Once the internal test has been printed properly, follow the instructions below to install a generic printer driver to know if HP printer driver is working fine:
  1. Click Start , Control Panel and Printers and Other Hardware .
  2. Click View installed printers or faxes .
  3. Highlight the printer to be removed.
  4. Click File and Delete .
  5. Click Yes when the deletion confirmation screen appears.
  6. Click File , Server and Properties .
  7. Click on the Drivers tab, highlight the printer to be removed and click Remove .
  8. Click Yes when asked to confirm deletion.
  9. In the printer folder , click on the Add a Printer task.
  10. Click Next and then, the Add New Hardware Wizard screen appears.
  11. Click Next on the Local or Network Printer screen.
  12. Click Next on the New Printer Detection screen.
  13. Click on the down pointing arrow next to Use the following port box and select USB001 or USB002 (virtual printer port for USB) and click Next .
  14. Under Manufacturer option, please select HP .
  15. Select the appropriate printer and click Next .
  16. Select Yes when asked Do you what to use this printer as the default printer? and click Next .
  17. Select Do not share this printer and click Next .
  18. Select Yes or No when asked Do you want to print a test page? and click Next .
  19. Then, click Finish .
  20. Try printing.
Jan 03, 2010 | HP DeskJet 5150 InkJet Printer
It will not print
Try to reinstall the printer driver
Nov 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Lexmark 2500 won't print but no error message
Yes,I unplugged the printer for several hours.  I also tried another printer and it would do the same thing.  No error message but would not print.
Oct 13, 2008 | Lexmark All-in-One Printer with PictBridge
Red light flashes after initially being green
I would say the printer has seen it's last hours. Try cannon, they last forever.
Sep 08, 2008 | HP PhotoSmart 7660 InkJet Printer
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
114 people viewed this question
Clive
Clive
