Question about Golf
I have recently purchased a G22 Yamaha Golf cart and it's just over 4 years old. The batteries were replaced about 4 months proir to my buying. it goes well but the charger shows after charging a yellow light winking although the baterries are fully charged. I have tried another charger and it shows the same result. My charger fitted to another cart works fine. Can you give me any idea what is wrong. As I said the batteries wouldnt be more than 18 months old
  • 101 Answers
When I have this sort of problem, I always double check battery connections, all should be clean and tight and the cables should be in good condition. Then I check each battery under load and see if any voltage drops too much. If that doesn't show any problems then I think a dealer might be your answer. A dealer would have a battery discharge machine that would how good your batteries are.
Posted on Jul 03, 2017
5 Suggested Answers
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
imend
  • 66 Answers
SOURCE: does anyone have service manuals for yamaha, e-z
HERE is a listing for all 3 of those.
Posted on Apr 13, 2009
  • 56 Answers
SOURCE: battery charger turns off before batteries are
The battery charger may be defective.
Posted on Sep 16, 2009
  • 174 Answers
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Posted on Nov 12, 2009
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
2008 Yamaha golf cart what drive does it have
It is either gas and has a gas tank or it is electric and has 4 x 12 volt batteries. Search Results
Owners Manual Download - Yamaha Golf Car
https://www.yamahagolfcar.com/ownersmanualdownload/ You can find them on the Yamaha Golf Car Owner's Manual section of the site. ... If you have a service related question, please contact your authorized Yamaha ...
Find Your Model/Serial Number - Yamaha Golf Car
https://www.yamahagolfcar.com/findyourmodel/
This overview page connects you with the resources of Yamaha Golf Cars dedicated to keeping your ... Follow the steps below to get information on services.
What Year & Model Is My Yamaha Golf Cart? ' GolfCartGarage.com
https://www.golfcartgarage.com/what-year-is-my-yamaha-golf-cart/
This guide will help you determine the year and model of your Yamaha golf cart. ... If the serial number begins with "JW9-300101" you have a 2013 Yamaha DRIVE. ... 2008. JW2-000101. YDREE. 2007. YDREPT (The DRIVE PTV). Beginning ...
Yamaha DRIVE Gas - Specs and Features - Golf Carts and NEVs
golf-carts.axlegeeks.com/l/7/Yamaha-DRIVE-Gas
The DRIVE by Yamaha is a gas powered specialty vehicle that can hold at most two ... The cart has a peak power output of 11.4 horsepower, 0% more than the ...
Yamaha G14 Golf Cart Specs ' Yamaha Year & Model Guide ...
www.performancepluscarts.com/yamaha-year-guide/
Need golf cart parts for your Yamaha golf cart, but don't know the year or model? Visit our website to ... Yamaha Serial Numbers will indicate the year of production. View the .... The Yamaha Drive is the newest addition the the Yamaha Golf Car line and began production in 2007. ... JW1-100101 = 2008 JW2-100101 = 2008.
2008 Yamaha golf cart what drive does it have Google Search
Mar 22, 2017 | Golf
How do I change piston rings on a 2005 Yamaha g22 golf cart engine?
get a workshop manual from the net and proceed as per any engine repair
the rings go in the allocated ring groove and need to be installed the correct way up
quicker and cheaper to get a qualified mechanic to do the job as the lip at the top of the cylinder has tom be removed first or piston damage / broken rings will occur
Aug 28, 2016 | Yamaha Motorcycles
What type of oil does the yamaha golf buggy use ?
Mike, Yamalube 4-cycle oil or quality SAE 10w-30 motor oil, is the oil for use in your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
what kind of oil 2 use
What Type Oil and Amount is used in Yamaha G22 Max Gas Golf Cart
What type of oil does Yamaha golf cart take
Aug 07, 2016 | Golf
How to time cam shaft and balancer shaft
Me would leave to professionals.
try Google search with question. Or better still You Tube Sam question lots of vids might just have your reqiuuiremrnts!
Oct 10, 2014 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Mar 26, 2014 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
Can valve seals be replaced without removing engine on a g9 Yamaha golf cart
If you can get access to the spark plugs easily and the rocker gear easily then you can do the job in car. You will need a tool to go in the plug holes and push up un the valve heads to hold then up while you replace the spring retaining collets. A tedious job but can be done.
May 27, 2013 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
Yamaha golf cart g22 owners manual
How to change the regulator speed
on Yahama G22 Golf Cart
Jul 04, 2012 | Cars & Trucks
Where can I buy a battery for the DX-902 Lil Driver golf cart? My golf cart doesn't work, so the first thing I think might be wrong is that the battery doesn't work. The golf cart sat in our...
Dear kimbroberg2
My husband and I did the exact same thing for our grandson when he was 8 months old. We pulled the car out of the attic last night and the battery did not work. My husband called the manufacturer customer service at 714-256-9888. He was told that the batter was too old and would have to purchase a new one. My husband called around for the item description that they suggested and found a comparable battery at Interstate Battery in our hometown. Good luck. I know we were very disappointed when this happened, but there is hope. Hope this helps.
Jun 28, 2011 | Dexton Kid Racer Battery Operated Ride On...
Golf Logo
467 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
