Question about GE Profile CustomStyle PSI23NGR Side by Side Refrigerator
Refrigerator wate leak
I have a GE side by side 20-27 with ice maker and water dispensor in door. The line to the water dispensor, inside the fridge is leaking. I cannot see WHERE it's leaking and cannot get at it because it's INSIDE. What to do? How to take it apart?
Thanks, Lin
  • faom550 May 11, 2010
    Where there is located the valve solenoid of the water dispenser in a refrigerator GE 20-27
  • 121 Answers
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Posted on Apr 21, 2008
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I PURCHASED A WHIRLPOOL GS5VHAXWY FRIDGE AND THE ICE IS NOT COMING OUT OF THE DISPENSOR WHAT IS WRONG WITH THE ITEM
first thing to check is that you have water going on the inside of the ice maker tray simply stick your finger inside and see if there is water if there is no water you would then look at the water valve or the line in the back of your fridge if there is water or rather there is ice inside the tray you would want to remove the ice maker and run the tray under hot water then reinstall to test if this does not work then replace the ice maker hope this helps
Jul 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not working but still makes ice
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR49X10173 to keep this from happening again ( comes with instructions ) .
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working.
replace the filter.
if tht dosent work replace the water valve....
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile CustomStyle PSI23NGR Side by Side Refrigerator Logo
293 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
