Question about Amana Casement Slider Air Conditioner
Ac is noisey and blowing water in the house.
Water hitting fan. also sprittsing water coming in house.
  • Amana Master
  • 43,501 Answers
Hi, The drain hole is plugged by dirt and/or dust....
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
Replacing cabin filter on 2001 Toyota Camry
It's probably got a leaf or some type of debris in the fan housing.
Jul 11, 2012 | 2001 Toyota Camry
Car turns on ok gets overheated quickly only the motor fans spins the ac fan does not the water pump looks to be working fine theres coolant in lines and they not collapsed i replaced relays and thermostat...
you know the water pump for that particular car is on the other side? is driven by the cam... either your water pump is not working,(to remove water pump you need special tool) did you change the termostat? temp. sensor?
Mar 28, 2011 | 1998 Cadillac DeVille
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
I had my a/c charged today because it has not been cooling the house down. It took less than a pound, but it still blows worm air. Fan and compressor all running. I cleaned outside unit, filters, replaced...
It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Jul 17, 2010 | Goodman CKL36AR36 Air Conditioner
Fan too noisey
that fan is called a inducer motor. remove the metal cover which the motor is attached to and adjust the small blower wheel. if that does not due it, replace the motor
Dec 15, 2009 | Goodman GMS90703BXA Heater
Very noisey fan/blower Lincoln Pizza oven 1300 series
yes, just fixed one. Take the screws loose that hold the cover (red metal) on to access the fan. Blow it out with an air compressor. Apply dry graphite powder (tube of lube) generously. problem solved!!
dellbrandt_3
Aug 20, 2009 | Lincoln AC-225 230V
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
Everstar MPK-10cr blowing hot air
Sound like the back lower motor that turns the fan wheel in the back has failed or needs to be lubricated. I used a little bit of silicon spray since it resists moisture. You can try taking the back off...then the front...then take loosen the front motor fan wheel housing and lift up enough to access the lower back fan motor. I then sprayed the motor housing openings as close to the inner part as possible. That also stops the common noisey fan issue.
Jul 20, 2009 | Heating & Cooling
Amana Casement Slider Air Conditioner Logo
144 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
