Word 2000, Mac OSX, print preview shows document that is justified right and left. Normal view is justified right and left. Print is only left justified. What's up.
  • hmalchow Apr 21, 2008
    I have many files that are both right and left justified, and they all print just as they show in the print preview window. So what is it in the Word software that is overriding what shows up in print preview? I don't really want to reload Word since it seems to work in every other case.
  • hmalchow Apr 25, 2008
    To quote you, "What you get in print preview is what is going to be printed, this is normal."
    Well what I get printed is not what is shown in print preview. The print preview is justified, the print is not.
  • 19,396 Answers
I do not know if you understand your problem, description is quite confused. I undestood displayed document format is different from printout. This (if this is problem) happens often because many Word views display document with a different look from what you get in printout. In this case check that you have NORMAL selected under VIEW menu.
Note: you do not get right justified and left justified. Justified is just an alignment that is not left or right, is just distributing words evenly within borders. Common horizonatal alignment in Word are
Left, Right , Center Justified.
What you get in print preview is what is going to be printed, this is normal. Again:
And get some tutorial, Word is not as simple as it can looks at first glance.
Follows some documentation
Office 2000
Microsoft Word Tutorial
Word 2000 Tutorial
Posted on Apr 21, 2008
    Genius:
  • 1,665 Answers
Paper alignment position must be adjusted.
  • 63 Answers
Uninstall your office2000..
and then isntall back..
it will be can fix it,and reset all your setting in msword...
good luck..
    Genius:
  • 1,142 Answers
Please give me a moment ill get back with a solution.
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 21, 2008
    Hi Its basically the page setup which needs to be set as default, and save the changes.
  • Maanita Chadha
    thats in the printer page setup.
  • Maanita Chadha
    Second option is to remove the word2000 from add remove programe and restart the system (mac) and reinstall the ms word again this should resolve the problem.
  • 3,037 Answers
Check the paper size first and let me know if you have it set for the right size in both page setup and on the printer options
Please let me what you find and I can further assist you with this problem
Thank you for using Fixya
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 21, 2008
    You have checked the printer properties and made sure that you are on the correct paper size right?
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • Benjamin Patri
    Benjamin Patri Apr 26, 2008
    well, maybe you will have to resort to redownloading it as it seems we may be running out of options otherwise. Please let us know if that fixes it.
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
"Error while printing"
Check to make sure that you don't have a bad cable. Sounds like it is bad. That is cheap to fix.
Nov 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
Cannot compress a PDF
I assume you have tried the "reduce filesize" command. Try opening the file in Preview and print it - in the print dialog box select the pdf button, type a name and print. You get a file in the location you selected. This can reduce the size considerably.
Jun 26, 2009 | Adobe Acrobat 7.0 Professional for Mac
Needs alignment
You have to go into maintenance and click on Print head Alignment.
The printer will align itself.
Mar 17, 2009 | HP Office Equipment & Supplies
Canon MP600 not printing on full page - in upper left corner
I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Print preview (on file menu) does not show entire page or only shows headers on gmail. And only prints whats previews.. The entire page is incompleteComputer is a Dell inspiron 9300
try to zoom it in.. Point your mouse pointer to the page of your document until it converts into magnifying glass pointer then left click on the page to enlarge the text size of your document to view all..
Feb 04, 2008 | Computers & Internet
Margins not recognised
Hi lerona - I have a 5600C series HP printer. You might try these tips:
Do a Print Preview to be sure the document looks right on your screen, then in Print Setup, down in the Zoom box check the Scale to Paper Size to be sure it isn't set for the wrong paper size. There's an arrow to scroll to the size you're printing on.
Then click Properties, then the Paper Quality tab. There's an item that says "minimize margins". You could try printing with the box checked (if it's not now), or unchecked (if it IS now) and see the difference. Click the Effects tab and be sure the "normal size" box says 100%, and that there's no check mark in the "borderless printing" box.
I print documents all the time, as well as photos, smaller sized items, cards, etc., and have had no trouble with the margins printing differently than my Print Preview shows on my screen. I hope these tips help you. Good luck, and feel free to email me if you have any success with my suggestions.
Jo
JokerGirl524@aol.com
Oct 28, 2007 | HP DeskJet 5150 InkJet Printer
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
