Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
How do you service the freon or r-134 for a mr slim a/c
  • tcool Jul 16, 2010
    what do you mean by "service" the freon?...and why? how do you know it's r-134?
  • 57 Answers
What do you mean by "service" the freon?...and why? how do you know it's r-134?
Posted on Jul 16, 2010
MXZ-3A30NA Unit takes longer to get cold and is making a slight noise. The red error light is flashing twice. It says that is IPM or PMC is faulty or compressor is faulty. Would this happen if it is...
low on freon, dirty coil, drain problem are the most common, (no particular order) it also could very well be the compressor, however you stated it takes longer to get cold...verify the drains are open and flowing, that all coils are clean, if they are the next call is to your service tech. Hope this helps
Dan
Aug 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Pressure readings
the metering device is in the outside unit on mini splits that is why the liquid line sweats. pressure reading depend on load high load high readings i would shoot for arount a 40f suction saturation temp
Jun 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim Mitsubishi - how much fill
On the data plate for the outdoor unit it will tell you what type and how much refrigerant you need. If the line set is longer than 25 feet you will likely need a bit more than what it says. A 40 degrees evaporator temperature is ideal, approximately 65 psi for r22
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 31, 2017 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi I have a Mr Slim Mitsubishi Aircon. I am not
my dear i am so so sorry but that oily liquid is freon an that will take a tech to come an find the leak an repair problem i wish i could coach you though to fix problem but i know you dont have the tools to fix it so hope i completed your question
May 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Jul 18, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Ac is blowing warm air in my 2005 sierra 2500hd duramax. Any idea
Your system has R-134 Freon in it. the 134 is made up of smaller molecules than the old R-12. The R -134 permeates through the rubber parts of the system. If the system gets too low on Freon, the compressor will stop coming on.(low pressure cut out switch). Have the system serviced with an A.C. machine that can vacuum, measure the amount of Freon in the system, and add the right amount. The machine can also inject die. Later the die will show up under a black light.This will show any leaks you may have.
May 23, 2009 | 2005 GMC Sierra 2500HD 4WD
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
Jan 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
117 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
