Question about Microwave Ovens
I have a tappan microwave model # tms137t1b1. Would like to know where the fuse is located.
4 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Microwave won't turn on anymore.
The model number may be on a sticker on the inside of the cooking cavity. Or it may be on the edge of the door, or on the lip inside where the door closes.
There are three protective devices in most ovens that can cause it to be completely dead. There's a main power fuse, then two safety thermostats. One is on the cavity to shut off power if something overheats, like if food catches fire. The other is on the magnetron tube (the microwave source) to shut the oven down if the tube overheats. You can test these parts with an ohmmeter. They should be short circuits if good, open or very high resistance if bad.
While the fuse usually blows for a reason, it can sometimes just fail as can the thermostats. So if the fuse is blown, change it. Just be sure to use the same type and rating. The special microwave fuse is available at Home Depot, Lowe's and appliance parts stores. If the fuse blows again right away, there's something more serious wrong with the oven. Then you should probably just replace it unless it's a very high-end model or a built-in.
If a thermostat checks bad, they are available from appliance parts places. Take the old one along so you get the right replacement.
If you have any doubts about working on a microwave, take it to a professional for service if you want to keep it. There are potentially lethally voltages exposed with the cover off and power applied. But if you've worked on electical appliance before and are careful, there's not much to doing it yourself.
Posted on Apr 24, 2009
  • 117 Answers
SOURCE: Microwave Model 87720 fuse location
Almost all models have the fuse located under the control panel .Should come off with a couple of screws but careful with the ribbon. Hope this helps
Posted on Jul 30, 2009
  • 127 Answers
SOURCE: Do anyone know how much
Is it in working order? Is it clean and free of cracks or scratches? Does it have all the manuals?
Posted on Jun 04, 2011
I have O'Keefe and Merritt stove with attached microwave labeled Tappan FCC ID ABM964To3. The "start" button on the microwave quit working. Can I get this repaired?
I had very old parts for the tappan units but they have been out of circulation for quite some time. Unless this is a new tappan that I am not familar with, Most of those parts are no longer available. The FCC ID does not help, you need a model number of the unit to try to look up parts. A Microwave puts out radio waves and such has to be regulated by the FCC. Federal Comunications Commission. That number wont help find parts for the unit. Sorry
Oct 03, 2017 | Tappan Microwave Ovens
Need tappan microwave owners manuel 56-9431
is there no user manual on online
how old is the microwave
good thing is you can still get parts
http://www.searspartsdirect.com/model-number/5694311005/1269/0123245.html
Feb 05, 2017 | Tappan Microwave Ovens
Where is the fuse in the Tappan Microwave (undercabinet) mounted
Quite often on an over the range model, the line fuse is located behind the grille or behind the controller, or sometimes in between the door switches.
There is a video available showing how to remove a typical over the range control panel assembly in under 5 minutes here.
You _should_ be able to find links to helpful exploded view diagrams and order parts here.
But if the oven is dead, first check the outlet under load (a toaster or heair dryer work best), then you can suspect the fuse, the magnetron thermostat (or TCO), the oven cavity TCO, or the controller.
Let us know if you need further help.
Jun 06, 2013 | Microwave Ovens
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Jan 01, 2009 | Tappan Microwave Ovens
Aunt bought a "display model" Tappan Over the Range Microwave Oven from Lowes. Did NOT come with the metal "MOUNTING PLATE". Where can I get a MOUNTING PLATE?
I bought a display model from lowes tappan over the range microwave oven, and do not have the mounting plate, How can I get one?
Aug 28, 2008 | Tappan Microwave Ovens
Tappan Microwave
This one has a fuse located behind the control panel, either on the floor of the oven or near the door switches it seems.
There is also a thermal fuse that looks like this, but it's not clear where it is. They are usually located on the magnetron.
You can find some info by searching for the model as 56-4884-10-04 here.
Aug 19, 2008 | Microwave Ovens
I have a Tappon Microwave model FMV151F. The screen reads -SE-. It will not do anything. What does this mean.
Our 17 year old Tappan Microwave Model # 564878 quit heating. Everything else works. Hard reset did not remedy the problem. Any suggestions?
Jul 13, 2008 | Tappan Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
