Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Installed the lamp that was burned out and nothing happens
  • Mitsubishi Master
  • 5,138 Answers
Look on your power supply board for Bad capacitors they will be swollen,vented or puffed up on Top if you see any that look like that they are bad ,You can also use your google bar and go to this website they will list parts and prices Encompass Parts Distribution
sometimes they will have Free service Manual you can print out online Type in your Model number WD52525 and on top left side page look to see if they list the free service manua
Wondering is all of your Fans Running defective Fan can cause set not to come on and the ballast board is what turns Lamp on, it connects to Lamp. Make sure Lamp Fan is running it is what keeps Lamp cool when set is on.Let me know if you need any more help.
Posted on Jul 16, 2010
Have a Samsung HLP6163wx problem
Hey friend:
most probably' 1) either your lamp was NOT installed correctly, or
2) lamp is bad - (it happened to me once, so no sweat!) - in this case you need to return the lamp in exchange for a new one.
Please watch any of the 'how to change the lamp on a dlp tv' video demo available on YouTube. Its not difficult. I already changed mine 3 or 4 times. Thanks
Jun 12, 2014 | Samsung HLN617W 61" Rear Projection HDTV
No picture no sound power light on
you have to check the projector lamp it is installed somewhere behind the tv look for something that says lamp or projector and take it out very carefully and check it out if it is burned if it is then you have to changed start from there or you have a short in your tv that dosent give enough power for the tv to start up
Dec 19, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
The first lamp "burned out" after only half a year of use and we only used it once a week. We bought a replacemente lamp and it burned out after three weeks... Someone plugged in the projector, the lamp...
The early lamp failures are due to poor air flow or longer hours of use.
So take care to clean the filters, see that the lamp brigtness is not put too high and reduce the hours of continuous use.
Sep 29, 2010 | ViewSonic Office Equipment & Supplies
Tryd to turn television on, and nothing happens, standby light flashes 13 times, please help
CCfl tube burned maybe most time or balancer problem Sony want the whole panel replaced you can buy the lamp and replace it or buy new panel for 1600$ Sorry bud replacing the lamp risks breaking the panel
Sep 24, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Acer aspire 1640
start up the computer and while its running, hold a flash light to the screen. If you can see any graphics on the screen, your lcd converter burned out. If you can seen nothing, its possible that the back light lamp burned out and the best option would be to replace the screen altogether
Jun 27, 2010 | Acer Aspire 1640Z Notebook
Lamp lcd
Make sure lamp door is properly on, there is a sensor on the door.
Sep 19, 2009 | Mitsubishi WD-62528 62 in. LCD Television
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
MY TV has a blue cloud on the left side
Blue lcd is burnt up.. Normally happens due to excess heat from poor ventilation or not changing the lamp at the required time.. Allways happens on the blue as blue light is the hottest wave length, and as the lamp burns, it shifts to that side. Nothing you can do but replace the lcd itself. From the image shown, looks like the unit uses sony lcds.. Sonys are well known for there burns.. No quick fix on this one.
Jan 27, 2007 | LG RU52SZ30 52" Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
