Also a Model and Manufacture of the unit would of been nice to know to really determine the problem. Also a Model and Manufacture of the unit would of been nice to know to really determine the problem.
You can't post conmments that contain an email address.
Try unplugging it; often reboots the chip/computer.
This is an LCD TV; often a blinking red light means a projection lamp is starting/trying t? start but in ¥our case it's probably just an old TV.
BTW...a new 4K 65" TV is less than $800 at Costco....
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement. Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Probably needs a DM board.This is avery common problem and the board may not be available anymore.Sometimes you can repair them by replacing bad capacitors on the DM board.
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Remotes can be ordered from various websites, I would check ebay, sony, those type of websites. The standby light flashing means your bulb on the TV needs to be replaced. Good luck.
