Soniq plasma tv keeps turning off by itself. Have to disconnect then reconnect the power to get it going again.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
mistersony
  • 320 Answers
SOURCE: Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
SOURCE: My Bravia Model KDL 46Z4500 (4 months old) turns
Replaced circuit board under warranty.
Posted on May 05, 2009
  • 8457 Answers
SOURCE: my plasma tv keeps turning itself off
Yes,Ur main video backlight board is dead,must be replaced.About $400 part and labors.
Posted on Oct 22, 2009
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Hitachi Plasma TV 55HDT79 that is turning on and off and back on
Go Setup in the menu. At the bottom you will see Reset The Software when power is turned off. Switch this to No.
Apr 21, 2010 | Hitachi 55HDS69 55 in. Plasma Television
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
My 52" plasma doesn't turn on. The green light comes on for about 2 seconds and then shuts off. It acts like it wants to boot up but goes right back off. It did this once about 2 months ago but then came...
Local service repair man fixed my Soniq 42" Plasma TV with same problem for $180 Australian.
He said it was the start up / power up circuit board and lucky I didn't keep trying to use it or it could have damaged the secondary circuit board as well.
Feb 18, 2010 | Televison & Video
Soniq 42'' QSP424T keeps freezing
I have been repairing Plasma Tvs for some 3 years now and have found most of the problems caused are by Capacitors.Once again Soniq are no different to the others.The fault is on the main Video Control Pcb.Replace Capacitor C529 which is a 470mfd25v.This cap is mounted next to an inductor coil at the top middle of the pcb.This Pcb is the one which has the tuner and all inputs on it.
Good Luck AND PASS THE WORD AROUND. LET US KEEP THE SERVICE INDUSTRY GOING.
VIEWCLEAR VISION PL BRISBANE AUSTRALIA.
Feb 16, 2010 | Televison & Video
TV freezes up most times when turned on either by remote or panel
$180 for local service repair man to replace the start up / power up circuitboard on my Soniq 42" Plasma TV. He mentioned if I'd kept using the TV any longer with this fault that it would have damaged a secondary circuitboard obviously then costing more to fix.
So anyone with a similar problem should stop using their TV asap to avoid further damage.
Regards,
Forum Member.
Feb 01, 2010 | Televison & Video
Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Jun 15, 2007 | JVC PD-42V475 42 in. HD-Ready Plasma...
Televison & Video Logo
1,188 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
