Question about Hyundai ImageQuest L90D 19" LCD Monitor
I have a 2 screen L90D setup. One screen is flickering on startup with no picture unless vga input plug is moved about. In this case it comes on breifly then off again. The cable has been replaced. Have had these monitors since 2003 without problems. The monitor has been stripped and nothing seen other than maybe the cable plug is not engaging far enough. It is ok for now. Are spares available in Whangarei or aucklandnz. Would appreciate your comments bill
Saigua
  • 981 Answers
SOURCE: MONITOR BLICKS AND NOTHING COMES ON THE SCREEN
Grateful how? Neverminding that detail, perhaps your screen's backlight or the power supply for it has failed. There's nothing to do but compare your unit's operation with that in the Service Manual or that of an operating unit; this is complicated by the fact that components might send an OK signal back to the main controller, so removing the bad parts will not necessarily mean the unit behaves normally otherwise. It may be as simple as rinsing the cat barf out with water and D.I. water (but you would still have to open the thing up on towels to find out.)
Of course the main power supply might also be faltering. you can probe the supply (with a DVM or scope) to see how steady that is.
Posted on May 11, 2008
SOURCE: missing plug for monitor
Well,
It doesn't have a s-vid connector, that's the plug for the powersupply.
Posted on Jul 03, 2008
Scott Ellin
  • 558 Answers
SOURCE: monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Posted on Oct 14, 2008
SOURCE: How to open the casing of my LCD Monitor Model HP w 1907v
I have a problem of opening the casing of my LCD Monitor, I want to open it so that I can visually check inside.
Posted on Oct 23, 2008
  • 8 Answers
SOURCE: 19inch hyundai imagequest monitor problem, no screen picture
The first thing to check is the power supply to the monitor. Mine went a while ago, black screen nothing happening, turns out it was just the power supply. A quick search on your favourite browser will probably turn up a supplier, I found one that just makes monitor power supplies, so it must be a common problem!
If you have a meter test the power coming into the monitor, or if you're unsure put it to your ear when its plugged in, you should hear a faint buzz which means its working. Also check for any breaks in the cable and/or if there is a fuse in the plug which might have blown**
**If a fuse has blown, it might point to another problem, but at least it's a starting point
Tal
Posted on Dec 09, 2008
Hp mini 110 screen fliclers if cursor moved to top of screen
Video drivers ? Reinstall them ? Does same thing happens on external monitor ?
Nov 20, 2012 | HP Mini 110-1037NR Netbook
I own a Toshiba NB 205 Notebook PC. I connected my flat screen TV to the notebook so I can use the TV as the Toshiba's monitor. I purchased a male-to-male VGA cable and plugged it into the VGA port on...
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
Jan 01, 2011 | Toshiba Computers & Internet
My projector does not show any picture,only show blue screen, does the lamp need replacement an if it does how it will cost
If you are seeing the blue screen at startup, then the issue is more than likely not the lamp. What is your input source and what inputs are you connecting to?
If you are using a laptop PC, note that the VGA output by default is not active. You have to go into display settings and change it to dual monitor for VGA output to work.
Oct 05, 2010 | Hitachi CPS210LAMP Projector Lamp
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Sinecerly
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
Red stripes on my monitor
This looks like a driver issue. Could be incompatible with a software you have installed or bad install.
Use a generic VGA to unintsall and reinstall driver for new card. Turn off computer and then install the new VGA. This should work.
May 09, 2009 | Samsung SyncMaster 214T (Silver) Monitor
Hyundai L90D+ Monitor Problem
Same problem L90D...clicking, flashing, not coming on. I just ordered a new monitor, but would love to know if this can be corrected.
Dec 17, 2008 | Hyundai ImageQuest L90D 19" LCD Monitor
Dvi to vga
You will not benefit from the DVI input unless you have DVI output on your computer. The great advantage of DVI is that the picture is transferred in digital form all the way from your computer to the individual pixels on the monitor. If you only have VGA output on your computer then you will never get a better picture than by using a good quality VGA cable to link that to the VGA input on your monitor.
The DVI plug is designed to carry both digital and analogue (VGA) signals on the various pins, so "adaptors" exist to allow a VGA monitor to attach to a DVI output on a computer. Monitors may also support VGA input from their corresponding DVI input sockets, but the picture quality will never be better than by using a good VGA cable because it is still not using the digital capability of the DVI interface. What's more, because you may need more adaptors and thinner conductors in the cable, you will probably achieve a marginally poorer picture than with VGA to VGA.
When you next buy a PC or a new video card, get one with DVI to take advantage of your new monitor. In the meantime, your best bet is a quality VGA to VGA link.
Sorry that's not what you were wanting to hear, but I hope it will help you avoid further frustration.
Sep 20, 2008 | Envision EN-985e Monitor
No access to half of menu
dry solder joints or bad input placement. Try jiggling the vga port on the projector or use a different projector
Jan 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Picture settings messed up!
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Dec 03, 2007 | Toshiba 27AF45 27" TV
Hyundai ImageQuest L90D 19" LCD Monitor Logo
43 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
 steve
steve
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
