Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Refrigerator top refrigerator not getting cold
  • 4 more comments
  • mcvern May 21, 2008
    I have the same problem except neither compartment cools. The electricity was turned off for an unspecified amount of time. Now the motor seems to be running as usual, making all the usual noises, but no cooling.
  • Anonymous Jun 11, 2008
    Freezer works. Refrigerator is warm. No cold air is being forced into fridge. Have had frost form in freezer before. Unplugging and totally defrosting seemed to temporarily solved the problem. But it keeps happening. This time, the fridge stopped with little or no frost forming.
  • jensarchi Jul 28, 2008
    unplugged the refrigerator overnight and plugged it back in after 24 hours and the freezer works fine but refrigerator didn't come back on
  • Anonymous Oct 06, 2008
    My refrigerator model is BBI20TE, an 8yr old bottom freezer stainless model. A couple weeks or so ago, the refrig portion stopped getting cold, so I cranked up the notch from recommended "mid range" to 5 then 6 then 7, coldest setting. It helped for a day or so, then nothing. I vacuumed the condenser coils, and that didn't help. I threw the fuses on and off (as recommended in the manual) and that seemed to help for a day. But, only if I left the setting cranked up all the way. Repairman who came over looked and said the refrigerator is running but the door isnt sealing properly, and he said it wasn't the gasket but rather the "collars" or some such plastic parts that go with the hinges on the doors. These are supposed to regulate the closure so warm air doesn't get into the refrig.
    (We have been unable to find these parts locally, so far, or - for that matter - anywhere at all). I have been forcefully pushing the doors shut to ensure good closure but the cold air is still not coming up to the refrig portion. Now, also, the freezer portion is not as cold as it was. Do you think it could be something else other than what he told me?
    Thanks,
  • Anonymous Apr 13, 2009
    the regfrigerator is not cooling
  • Timothy Brooks
    Timothy Brooks May 11, 2010
    Is freezer OK? Does it run..all the time?
No cooling in either top or bottom. It runs most of the time but it does shut off once in a while.
Posted on May 21, 2008
  • 27 Answers
Pl check the thermostat, it may be faulty. or the cool air path is blocked, or air flow nob is in closed possition
Posted on Mar 06, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Frigidaire top freezer refrigerator will not get cold
Contact a professional. There is a restriction from the freezer section to the refrig section that helps make it cool.
Aug 04, 2012 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
Kenmore refrigerator top works but bottom doesnt get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator is cold in the freezer, but the top of the frig is not cold. Is there are fan to cool the top part of the frig?
heatman101
Dec 05, 2010 | Amana ABB1927DE Bottom Freezer...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
328 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
