The keyboard works outside of the windows 7 environment but once it turns on the keyboard and mouse dont work
  • 146 Answers
Have you tried a different keyboard and mouse?, your keyboard and mouse on a different pc?
Is it usb? ps2 wireless?
Only the wireless option would need a driver
Usb will work if they are ok
ps2 may need settings changed in the bios to make it work.
Posted on Jul 16, 2010
Suppose the numeric keypad of a keyboard is not functioning correctly, and when a numeric key is pressed, the keyboard redirects the cursor. Provided that the keyboard is not faulty, which of the foll
what os youre using ?
if windows os then maybe the mouse keys on Accessibility feature was turned on
how to check it on windows 8 :
1.Swipe in from the right edge of the screen, and then tap Search. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
2.Tap or click Settings.
3.In the search box, enter Change how your mouse works, and then tap or click Change how your mouse works.
4.Under Control the mouse with the keyboard, check the Turn on Mouse Keys check box, if selected then deselect it and then click OK.
On Windows 7 :
1. goto start -> control panel -> ease of access center
2. click on use make mouse easier to use
3. check the turn on mouse keys check box, if it checked then deselect it
4. clik ok
Sep 20, 2014 | Computers & Internet
I have an ocz equalizer, on windows 7 64bits, never had problems before, now the mouse in a iregular timing, connects and disconnects... i dont know what else to do... please help me
I have an ocz equalizer and Windows 7 64b like you, since 4 days my mouse have the same problem, the buttons works but the movement dont. The official web http://www.ocztechnology.com/drivers/Equalizer_Mouse/ don't have drivers for Windows 7. I'm searching a solution... but, help!
Feb 19, 2010 | OCZ Equalizer Laser Gaming Mouse (Mobile...
Gateway 2005, windows xp, pentuim 4.trying to fix my girlfriends computer. We are in the process of instaling a geforce video card. I installed the video driver on on her harddrive with my pc. After in put...
is it a usb keyboard? If so it must be enabled in BIOS. Also if enabled OK, then when at desktop next,, unplug and re-plug into another usb socket and it should be detected and a driver will install, thaat may fix it?
Feb 18, 2010 | Computers & Internet
Microsoft laser desktop 5000 vs Windows 7
The software might not be compatible. but for you to use the wireless keyboard and mouse you don't need a software just plug the wireless adapter and sync the keyboard and mouse . it will start working
Jan 17, 2010 | Microsoft Wireless Laser Desktop 6000...
Acer Aspire 5532 Keyboard works in BIOS, but stops working once Windows 7 loads. Same with the touchpad, once Windows 7 loads it stops working. However I can plug in a usb mouse and that will work.
look there is a problem with the touchbad diver and this is common but the keyboard must work it s nothing with the keyboard so please check if all the key board works under another operating system and then if it wrks try to reinstall windows 7 again and it must work conntact me if you still have a keyboard problem you must try to plug a usp keyboard and see if it work so you have a problem with your board again if it worked you have a problem with your keyboard if it didn't work then try install windows 7 agin
Nov 03, 2009 | Computers & Internet
Wireless mouse and keyboard issues
If you have both sets of keyboard and mouse plugged in, turn off the computer and remove the old mouse and plug in the new mouse. Reboot and if necessary use the keyboard to login. Once windows is loaded let it detect the new mouse and then shut down again. Take out the old keyboard and reboot. You should now be able to use both new pieces without problems.
Jun 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
maybe it is full of dust on those buttons. Try cleaning it with a duster of mini-brush because it interrupts the function.
Jan 30, 2008 | Logitech MX3000 USB PS/2 Wireless...
Keyboard/mouse not working
You need to restore to a previous date before you installed the wireless mouse / keyboard.
If that dont work then your only solution is to format and reinstall since it might be you could have damaged a few vxd files window's needs to use those devices
(THIS IS ASSUMING THE MOUSE AND KEYBOARD WERE CONNECTED PROPPERLY) AND THEN THE SYSTEM WAS TURNED ON
if that wasnt done
shut down compuer
2.) plug mouse into green ps2 port and keyboard into the blue one
3.) turn on computer
Jan 03, 2008 | Computers & Internet
Mouse and keyboard
How to navigate Windows using a keyboard. Once in the Start menu you can use the arrow keys on the keyboard to move ... (Not only does this help users who do not have access to a mouse)
Mouse not being detected in Windows 9x, ME, 2000, XP, or Vista. This issue can be caused by one or more of the below possibilities. ... If the other mouse works in this computer attempt to use the mouse not working
Windows 3.x help and information Controls:, keyboard / Mouse. operating system:, DOS 3.1 and Higher ... WIN /3 - You can use this option if you want Windows to run in 386 enhanced mode even
What is ESD or ElectroStatic Discharge Setting on a chair can generated more electrostatic. Cords - Make sure everything is removed from the back of the computer (power cord, mouse, keyboard
Good Luck..Please dont for get to Vote, Thank You.
Dec 17, 2007 | Acer Aspire 5100 3010 Notebook
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
