My ac adapter is very loose fitting when plugged into my Dell Inspiron 1525. Any suggestions?
  • 4,234 Answers
The most likely prolem here is that the connections at hte power jack have loosened. This should be repaired ASAP as the problem will continue to worsen. This can be easily be fixed by a qualified tech. It will take longer to gain access to the jack area that it will to resolder the connections. Please have this repaired. If the jack is physically broken, it can be replaced for less than $10.
Dan
Posted on Jul 16, 2010
  • 146 Answers
Its worn and therefor loose, only option is to get a new power input socket fitted
Battery light blinking orange once, then green twice
LOL, It means whoever sold you that Power Cord probably sold you one with the interchangeable end that can plug into any laptop. If it's not the interchangeable end type, they sold you one that is not compatible with your laptop. Get rid of it in a hurry before it burn out your motherboard. You my friend need to get on ebay and purchase a power cord designed specifically just for an Dell Inspiron 1525. All you need to search for on ebay is Dell Inspiron 1525 AC Adapter. They probably cost less than $10
Mar 21, 2012 | Dell Inspiron 1525 Notebook
My lapyop automatically switched off when battery got drained .When I tried to restart it ,it is not functioning..There is no light signal and no response for button pressing......
It appears that the AC adapter is not powering the system. If you know anyone with a later model Dell, the AC adapters are inter-changable (If the plug fits, you can use it) If the system powers on, the you need a new (Dell Branded) ac adapter as non-Dell adapters will not charge the battery.
If the DC in jack of the chassis is loose or the LED on the AC adapter goes out when plugged in to the system, then you may have a bad motherboard.
http://support.dell.com/support/edocs/systems/ins1525/en/SM/sysboard.htm#wp1180315
Jul 17, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Does it mean that my battery on the Dell Inspiron 1525 is out if it won't charge anymore. It also won't work when the battery is removed and the AC adapter is plugged in
It's not the battery than. If you ask me - two possible problems:
1) The AC adapter is shot to hell and you need to replace it
2) The motherboard input plug is damaged and you need to service it.
Further diagnosis:
Test the AC adapters output plug with a voltage meter (if there is nothing than that's the problem, if you get a positive reading - its fault nr 2)
You can also try to borrow a AC adapter of a friend (only if it's the same model) and plug it in.
Best of luck.
Nov 12, 2009 | Dell Inspiron 1525 Laptop
Inspiron 1525 plugged in not charging
replace u r computer, as the cost of mother board and the age of your computer I suggest replacement.
Jun 20, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1501 ac adapter problems
Send it back and get another . It is obviously defective if the other works on your computer.
Feb 08, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
