Question about Sanyo DS32920 32" TV
Hellomy sanyo model#DS32920 has a green hue down the center of the screenan orange line along the left side of the screen and a blue line in the top right corner. Also any popup windows displaying letter or #rs are doubled up and fuzzy. Any ideas?
4 Suggested Answers
  • 41 Answers
SOURCE: TV screen is frozen
Look for a button on the remote or front of the set that is labeled input (could be tv/video) this switches between video inputs and the tuner.
Posted on Dec 21, 2008
homedesigner
  • 583 Answers
SOURCE: intermittent pixel scrambling on screen (have
Usually the result of a weak or interruption of the signal. If it occurs on all channels, look into getting an inline amplifier. If you have several splitters going to different tv's or a multiple splitter, the signal is degraded each time the signal is split. You can test this be temporarily making a direct link to the TV from the cable source. If it clears up, then you know you need to amplify the signal.
Posted on Feb 24, 2010
SOURCE: SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Posted on Apr 08, 2010
Sanyo lcd32k30td tv has blue screen , get sound no picture , cannot change channels or use any controls on remote or side of tv.
switch it off for 10 seconds .. then press button TV/AV
its probably due to power fluctuation ..
if the problem occurs check for local warranty service or service center
Mar 29, 2011 | Sanyo DS32920 32" TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
My sanyo tv screen keeps disappearing with green lines on thris
Green retrace lines could me two things, the green gun in the CRT is shorting out and that is the picture tube, and it is not worth fixing. Another thing that it could be is a bad neck board and the green driver transistor is shorting, but that would be green all the time, I would say it is the picture tube, and buy a new TV.
Feb 23, 2011 | Sanyo DS32920 32" TV
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage area....it will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Sanyo Bravo
check if its on all the video sources. check it on dvd if its there then contact the customer care
Jan 07, 2009 | Sanyo DP32746 32 in. LCD Television
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Sanyo DS32920 32" TV Logo
55 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
