Question about Kenmore 45081 Front Load Washer / Dryer
Kenmore Elite front load dryer
Dryer panel clicks like its turning on but doesn't. What could be the problem?
  • 246 Answers
Probably a thermal fuse. You'll need a continuity meter to check it, though. Once you get one, unplug it. Remove the lower panel on the front. Beneath where the lint filter sits is your lint duct. Remove it (screws at top left and right and clip at botom center) Behind it is a white peice of plastic with 2 blue wires. Unplug them and check across the two prongs on the white thermal fuse to see if it is good. Replace if nessciary. If it is bad check your vent (dryer to wall and wall to outside) for restrictions or blockages.
Posted on Jun 16, 2008
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
I have a Kenmore Elite Front load dryer He4 and the door handle has broken. Can I get a replacement handle from you?
HI. we don't actually sale replacement parts but, i can refer you to a great online supply store that will meet your needs. just click on the link below to be directed to the repair clinic.
Jul 13, 2009 | Kenmore 45081 Front Load Washer / Dryer
Either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Mar 28, 2009 | Kenmore Elite Oasis 7808 Gas Dryer
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 45081 Front Load Washer / Dryer Logo
Sal De
 Brian Main
Brian Main
