Question about Amana ARB8057CSL Bottom Freezer Refrigerator
My top refrigerator is warm
Where is the reset pressure switch because my top part warm
  • jamesfbaylor Sep 14, 2008
    both fridge and freezer are not cooling properly, i here a click occasionally but i am not hearing the fan ...
  • Timothy Brooks
    Timothy Brooks May 11, 2010
    There is no such switch that I am aware of. Any other clues?
  • 149 Answers
Verify if the condenser has a fan if so, suspect the fan defective and coil dirty or clogged,clean coil and replace fan (if any/defective). 2nd possible fault that your defrost system has a possible failure.If your good with an voltmeter you can put it on the "audible" mode and check your defrost heater if good and if it uses an defrost timer or adaptive defrost board suspect that faulty also
Posted on Apr 21, 2008
Why does the compressor run only for about 5 minutes then shut off, leaving the fan still running?
It seems that you have a system short. You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
If this doesn't help I would recommend calling a ac service company.
AC Repair Coral Springs
Apr 24, 2015 | Heating & Cooling
Light on but not cold
We could use a few more details to identify the problem. Does the fridge turn on fine and run (is there a noise at the back?) Does the back get warm at all? Have you defrosted it recently? most similar fridges do not have a resettable "pressure switch". some have a resettable thermal cutout on the compressor, usually on the side. unplug the fridge from power before rooting around the compressor area. Hope this helps - awaiting more info :)
Sep 08, 2007 | Amana ACD2234HRS Side by Side Refrigerator
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1997 jetta ac works for one minute then warm air blows
check the refrigerant level. The compressor is running until the low pressure or high pressure switch switch cuts it off.
Running the unit without enough refrigerant will damage the compressor because the lubricating oil is dissolved in the refrigerant. This is the reason for the low pressure switch cut off--to protect the compressor from damage.
If pressure gets too high, the compressor seals will blow. Thus the reason for the high pressure switch. Too much refrigerant or too much air in the system (due to a leak) will cause high pressures.
If refrigerant level appears to be correct, then suspect trapped air from a leak causing a high pressure cut-off. If refrigerant is low, suspect a leak causing a low pressure cut-off.
Mar 02, 2011 | Volkswagen Jetta Cars & Trucks
Freezer is warm, not freezing at all, fans run
If the fans your talking about are in the refrigeration section, then the unit is not in defrost. The interior fans shut off during the defrost cycle.
There is a condenser fan motor in the machine section by the compressor. If it fails, the problem you described can occur.
If that fan motor is still, and the compressor is cool to the touch, then no power is getting to the refrigeration section.
Could be a bad thermostat, or the unit has tripped off on the high pressure safety switch. The high pressure switch can be one of 2 styles. Auto reset, which means it will try to restart the compressor when the pressures become normal. The other has a lock out feature that requires it be reset manually. If it goes out on the high pressure switch, once reset, check the condenser fan motor to make sure it is running and/or excessive dirt in the condenser, which must be blown out.
Other causes can be a total loss of refrigerant, or a compressor that won't run.
Short of a broken wire all items listed except for a dirty condensor and reset of the high pressure switch, require a decent knowledge of electrical, Knowledge in the use of a VOM meter and amp-probe, as well as a set of refrigeration gauges.
Oct 30, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Freezer and fridge not cooling
compressor not on most likely.listen for a low hum inside or low down close to the floor in front of it.If no hum its not on.depending on age you can install a hardstart for it and get more life out of it.
Sep 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigator not cooling coils clean and compressor working
check defrost timer control on older located on bottom by the condenser coils look at elect diagram to see if one is hook up
Sep 24, 2009 | GE Refrigerators
A/C problem
The low pressure cut out switch located in the larger refrigerant line (the low pressure side) in front of the evaporator (passenger side, under the hood) may be sensing low refrigerant. Also the low pressure switch may have a bad electrical connection or the switch may be going bad.
Jul 05, 2008 | 1981 Chevrolet Corvette
Top portion of rrefrigerator on refrig side is hot
Check to see if refrigerator door is even with freezer door at top, or is it lower. If lower, the light switch may not be contacted fully. Remove toe plate , bottom front on fridge. Under refrigerator door bottom hinge is a threaded rod. Adjust this to raise door to make level.
Nov 20, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
191 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
