I have bought a new nordmende nm2245dvd which when switched on for first time install after screen appears asking for country , language which I select and then it went to standby and will not switch back on ?
  • 15 Answers
SOURCE: Changed language to french!
first, press the menu button on the click wheel until your screen goes to the home screen (main menu). you will know you're there when the screen doesn't change anymore. select Reglages, then Langue, and finally English.
Posted on Dec 20, 2007
  • 31 Answers
SOURCE: arcam alpha 7 amplifier goes back into standby when volume is turned up
Can you, or can someone you know, check for DC voltage on the speaker terminals when the amp is on, but not playing? Ideally, the meter should read 0mV with no signal, and certainly less than +/- 10mV. Anything over +/- 30mV is worth having checked out, especially if it changes as you turn the volume knob with no signal applied.
Posted on Sep 20, 2008
  • 43 Answers
SOURCE: Date & Time loss with Exilim EX-S600
Good Morning :
Hope that you are wellJ
This is the response from Casio:
"The date and time will reset and the setting will need to be readjusted. The camera does not have a separate battery for the clock. The date and time will reset whenever the camera is not supplied power by the battery and USB cradle for about 24 hours."
Sounds a bit messy to me.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Posted on Sep 30, 2008
  • 10 Answers
SOURCE: phone restarts on its own
I tried to switch on my cell with the data cable already attached.It kept on beeping on my pc but cel did not switch on.I detached the cord and switched on my cel.It showed the nokia logo and kept switchin on and off.Later i removed the battery,replaced it back and switched it on.And BANG!!! After 5 minz it switched on!!!!!!!!
Posted on Apr 13, 2009
SOURCE: same- how do you reset the default country?
Achieve global reset by pressing down on the bottom right corner of the touch screen (i used a pencil eraser) while restarting the GPS. You will default back to factory settings and can re-select your language of choice then.
Posted on Jul 29, 2009
How do I go back to the very first screen when setting up a notebook in windows 8.1
Hummmm when I bought this notebook it already had all that information in and I never saw those but I know all countries do not do things the same
Jan 25, 2015 | Medion MD-40954 Notebook
Hi! I bought a new asus eb1505 4GB RAM 500G disc. I switched it on, it asked me for some settings (language, EULA etc.), I set an username and a password. Than it said it should restart. Ok. After...
What I would do is to on post pressing your PC's power on begin to click over and over till you see a screen the F8 key. Go into Safe Mode or you may be able to Start Windows Normally. If this does not work then you must either do a Recovery or Run Windows disk.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Aug 30, 2013 | ASUS EeeBox PC EB1505-B011M Intel Celeron...
I bought my hp photosmart c3183 from middle east but the cartridges 131 and 135 are not available in pakistan, instead hp 92 and 93 are used in pakistan for this printer. i installed 92 and 93 cartridges...
Have you reset the region from the menu?? To do so kindly follow the procedure below
The language and country/region setting determines which language the HP All-in-
One uses to display messages on the color graphics display. Usually, you set the
language and country/region when you first set up the HP All-in-One. However, you
can change the setting at any time by using the following procedure.
1. Press Setup.
2. Press 6, and then press 1.
Finish setup
This displays the Preferences menu, and then selects Set Language & Country/
Region.
A list of languages appears. Press or to scroll through the list of languages.
3. When your language is highlighted, press OK.
4. When prompted, press 1 for Yes or 2 for No.
The countries/regions for the selected language appear. Press or to scroll
through the list.
5. When the country/region you want to select is highlighted, press OK.
6. When prompted, press 1 for Yes or 2 for No.
If you require more assistance, feel free to reply to this post,
Thanks for asking FixYa!
Regards, Bilal
Feb 09, 2011 | HP Photosmart 3310 Printer
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
How do i convert my acer netbook to english language from chinese?
You have to download and install a LIP (Lanaguage Interface pack) A LIP changes everything in Windows, to another language. but you cannot change the language Windows uses on the screen unless you buy the English version.
However IF it is Chinese Windows, then you will never really be 100% converted, the BEST way then, is to remove OLD Chinese Windows, and install a NEW English Version.
Normally just go to Control Panel, Regional and Language Option, click the Language tab, Details radio button, click Add radio button, click the drop down box and select the language. It may ask you for the distribution disc. Once multiple language had been added, a language switching Task Tray will appear near the normal Task Tray in the lower right corner. Shift-Alt will also switch the languages.
In Windows 7's Search programs and files box type Anytime and click on the Windows Anytime Upgrade icon that appears. Purchase a Windows Anytime Upgrade product key for Windows 7 Ultimate edition and upgrade to Windows 7 Ultimate. Afterward, visit Windows Update and download the English language pack.
Aug 28, 2010 | Acer Computers & Internet
My HP PSC 750 printer screen seems to be in German. How do I get an English display? Diana
CLICK HERE for your owners manual in PDF format.
Page 36 of the manual states the following -
HP PSC 700 Series
The following steps help you change the language for your unit.
To do this using the front panel
Press Menu.
2 Press until Maintenance appears, and then press Enter.
3 Press until Set Language and Country appears, and then press Enter.
4 Press until the desired language appears, and then press Start Copy, Black or
Color.
5 Press Start Copy, Black or Color to confirm.
A prompt displays asking to select the country where your HP PSC will be used.
Specifying the country sets your photo sizes applicable for your region.
6 Press until desired country displays, and then press Start Copy, Black or
Color.
7 Press Start Copy, Black or Color to confirm.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 04, 2009 | HP Office Equipment & Supplies
Brazilian regionalization zone code???
To change the region there is a special report to be printed from the printer from which some numbers are to be taken which belong to the printers firmware these numbers are to be given to HP they ll run an algorithm on it and then it can be regionalized... one printer can only change a region 3 times....
Try
1. Press Setup until Preferences appears, and then press OK.
2. Press until Set Language & Country/Region appears, and then press OK.
You are prompted with a list of languages. You can scroll through the list of
languages by pressing or .
3. Press OK on the appropriate language.
4. When prompted, press OK to select Yes or Cancel to select No.
You are prompted with a list of countries/regions for the selected language.
5. Press to select the appropriate country/region, and then press OK.
6. When prompted, press to select Yes or No, and then press OK.
You can confirm the language and country/region by printing a Self-Test Report,
as follows:
1. Press Setup until Print Report appears, and then press OK.
2. Press until Self-Test Report appears, and then press OK
Thanks.
Feb 21, 2009 | HP Office Equipment & Supplies
Cant get it to read in english
Change the front-panel country or language on HP PSC 750. (From HP PSC 750 manual - bpu02250.pdf)
1 Press Menu.
2 Press a194261.gif until Maintenance appears, and then press Enter.
3 Press aa48bd2.gif until Set Language and Country appears, and then press Enter.
4 Press 98782b3.gif until the desired language appears, and then press Start Copy, Black or
Color.
6 Press b3bb801.gif until desired country displays, and then press Start Copy, Black or
Color.
Feb 01, 2009 | HP PSC 750 All-In-One InkJet Printer
HP US region code for HP PSC 1610 All-in-One Hi,I bought my HP PSC 1610 All-in-One in Germany and now have moved back to the US. As it is regionalized to Europe region code, I need to change it to US...
The control panel display shows the wrong language
Solution
Usually, you set the language and country/region when you first set
up the HP All-in-One. However, you can change these settings at any time by
using the following procedure:
as follows:
Nov 16, 2007 | HP PSC 1610 All-In-One InkJet Printer
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
