Question about Dell Vostro 420 Desktop Computer
Amber light on the front, PC not booting up - Dell Vostro 420 Desktop Computer
Usually a flashing amber light means the power supply is bad, If its solid its probably another device on the system board that could be bad or not installed correctly.
Hope this helps
Posted on Jul 16, 2010
Why am I unable to boot my desktop dell
Several possible reasons, best (if not under warranty) to check RAM memory for faulty one, seems like possible memory of AC issues.
Aug 26, 2014 | Dell Dimension 9200 PC Desktop
MY DELL IS OPTIPLEX 760SFF, IT NOT BOOTING, SHOWING AMBER LIGHT ON THE POWER BUTTON WHEN PLUG TO POWER.
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Proton
Aug 10, 2010 | Computers & Internet
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Amber lights at the front of my dell dimension cant boot up
This can mean various things, but I've had a few of these happen and it's usually caused by a failed power supply. Calling their tech support they will ask you to remove memory and disconnect hard and optical drives then try again. If it still is amber, it's a power supply.
Oct 11, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Toshiba satellite A50 error code
try removing the memories, hard drive, optical drives and power on your computer. if the computer beeps it is an indication that your computer is working and one of the remaining part could be causing the no boot. if after removing all the parts your computer will not beep or the flashing amber light will not change it looks like you will need to replace your motherboard
Jun 19, 2008 | Computers & Internet
Open Questions:
Fixed amber light - start,shut down itself and restart itself Hello, Yesterday morning, I have installed a second screen linked to my graphic card. I tried to install a 3rd screen on the VGA motherboard, and it didn't work so I take it off. I could work on the computer with the 2 screens all day long. I left my office and the screensaver started. When I came back, I couldn't started my computer and my screen didn't light on after moving the mouse or writting on the keyboard. Then, I shut down my computer to restart it. Here is the problem. 1) The power light was fix and amber, the ventilation works. 2) 2-3 seconds later, it shuts down itself for few seconds 3) And it restarts itself. However, I still have the fix amber light and the screen is not activated. I checked the wall plug, I reduced the number of device on the trailling socket. I removed and reinstalled from the motherboard the RAM memory card and my graphic card. I tried with only one screen. But I still have the same problem. Do you have any ideas about what the problem could be: - Is the motherboard over? - Is the graphic card over? - Is the power bloc over? How could I evaluate which component is not working correctly? Thanks for your precious help. My configuration : - Intel Core 2 Quad Q8200(2,33GHz,1333MHz,4Mo) - Windows Vista - Cordon d'alimentation : Européen 2M - Carte graphique : 256Mo DDR2 ATI Radeon HD 3650 (pleine hauteur,sortie DVI/HDMI/DisplayPort,Double affichage)
Mar 01, 2017 | Dell Vostro 420 Desktop Computer
Dell Vostro 420 Desktop Computer   Logo
878 people viewed this question
Alun Cox
