Question about Epson TM-U950 Receipt-Journal-Slip Dot Matrix Printer
TM-U950 slip paper mode
I dont know how to enter printers slip paper mode. The journal/slip button is not lit or blinking, I can only print on 2 rolls papers. I have tried to insert slip paper from slip feeder, but nothing happen. From the manual that I received with the printer, I cannot find any info about setting printer into the slip paper mode. I dont know if printer doing it auto when You try to insert paper, but nothing happen to me.
The usage of the printer is truck LPG delivery.
Thank You in advance!
Best regards
Josip Ivanisic
4 Suggested Answers
SOURCE: how to auto tear paper after printing receipt is completed.
I had the same problem, and after going through so many articles, I was getting the message but didn't know how to pass the escape codes. All you need to do is pass the ASCII code of the characters needed preceded by the ASCII code for Escape. In Delphi, we use Char(27) or #27. In my case I used ESC 105 Null and it worked. Here is my sample code, with Str being a TStrings class (A string array object) and the WriteTextFile being a procedure to write the Strings to LPT1 as plain text. Str.Add('*********END**********'); Str.Add(''); Str.Add(#10); Str.Add(#10); Str.Add(#27#105); WriteTextFile(dmMain.LPTFile, Str); any questions, holla me at gachugu@yahoo.com or igachugu@gmail.com
Posted on Jun 10, 2009
wiqi546
  • 1511 Answers
SOURCE: where can i download driver for tm-u950
You can get it from Here and also from Here
If I was helpful, Kindly do Rate!
Posted on Jul 18, 2009
SOURCE: automatic document feeder pulls paper through only part way
You need to replace the document feeder motor the gears on the motor shaft are split and slipping. New motor is 12.72 at http://www.compassmicro.com/parts2.cfm
Posted on Jul 13, 2010
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Where is the reset button on a epson tm-u950 printer
There isn't a reset button.
Unplug from register and wall. Wait 10 seconds, and plug back in. That's the only reset.
May 06, 2012 | Epson TM-U950 Receipt-Journal-Slip Dot...
Printer not loading paper to print / error #3
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Jan 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Blinking lights
this means your printer wast pad is full this is now oyu reset your printer but make sure you have put new pads in 1st and dont for get to rate plz
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Sep 11, 2008 | Epson Stylus 2200 InkJet Photo Printer
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Journal receipt won't print.
Hi. The journal side should always print (right side of printer). There is no way to turn it off. If it is feeding the journal paper, but not printing, then you may have the roll in back to front (in the case of thermal printers). If it doesn't feed at all, then you may have a feed problem. In this case it will usually be printing over the same place on the roll continuously. Another thing to test is whether it prints on both rolls when printing Z reports.
If none of this helps, then please let me know the brand and model number, and I will try to suggest more checks.
Mark
Aug 30, 2008 | Casio Parts Cash Register PC Desktop
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Receipts
theres no platen gap lever/adjuster on those type of printer which are normally found on dot-matrix printers
Feb 12, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U950 Receipt-Journal-Slip Dot Matrix Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
