Question about Pelonis Oil Heater HO 157
I need instructions on how to get my Westpoint Oil Heater to ignite. It is an old heater in a house I have purchased. It has a electrical connection, and then some buttons on the top. No model number on the exterior.
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
SOURCE: vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Posted on May 05, 2008
tinytrees
  • 92 Answers
SOURCE: Instruction manual for hz705 honeywell oil heater
May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
Posted on Jan 23, 2009
co7196
  • 3433 Answers
SOURCE: Replace Bulbs in Dimplex HUR20 (HURSEY) OPTIFLAME FIRE
send front ,side, and back views to co7197@hotmail.com and I'll give it a look.
Posted on May 20, 2009
SOURCE: i need a switch for my heater,how do i order the
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Posted on Jan 08, 2011
How to change the thermostat
This is for the 2.7L:
2.7L Engine
  1. Disconnect negative cable.
    CAUTION
    Do not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
  2. Drain cooling system.
  3. Remove radiator lower hose from thermostat housing.
  4. Remove nuts from heater tube flange studs.
  5. Loosen starter bolt at heater tube bracket.
  6. Pull heater tube out of thermostat housing and position out of the way.
  7. Remove bolt and two studs.
  8. Remove thermostat housing, O-ring and thermostat.
  9. Remove thermostat housing bolts.
To install:
  1. Clean gasket sealing surfaces.
    NOTE
    Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  2. Install thermostat and seal into thermostat housing .
  3. If removed, install two studs.
  4. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  5. Lubricate new heater return tube O-ring with coolant.
  6. Position heater return tube flange over two studs. Install nuts.
  7. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  8. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  9. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  10. Refill cooling system.
  11. Inspect for leaks.
  12. Connect negative cable.
This is for the 3.2L and the 3.5L:
3.2L & 3.5L Engines
    CAUTION
  3. Raise vehicle on hoist.
  4. Disconnect electrical connectors from engine oil and power steering pressure switches.
  5. Disconnect radiator and heater hoses from thermostat housing.
  6. Remove thermostat housing bolts.
  7. Remove housing, thermostat, and gasket.
    NOTE
    The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing using a suitable hand held grinder. It is not necessary to restake the replacement thermostat into the thermostat housing.
To install:
  1. Position gasket on thermostat and housing.
  2. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
  3. Install radiator hose.
  4. Install bypass hose.
  5. Connect electrical connectors from engine oil and power steering pressure switches.
  6. Connect negative cable.
  7. Fill cooling system.
  8. Inspect for leaks.
  9. Lower vehicle on hoist.
Nov 01, 2010 | 2002 Dodge Intrepid
Needto replace heater core in 99 ford taurus,need help
Instructions Things You'll Need:
  • Replacement heater core
  • Clean container
  • Wrench
  • Screwdriver
  • Steering wheel nut
    Removal
  1. Disconnect the negative battery cable and wait at least one minute for the air bag system to lose power. Make sure the front wheels are straight ahead and lock the steering column.
  2. Detach the air bag module by removing the bolts from underneath both sides of the steering wheel and the electrical connector. Remove the steering wheel bolt and press the wheel away from the steering column. Remove the lower steering column cover.
  3. Insert a 1/8-inch wire or pin punch in the shroud hole under the ignition switch while it's in the "Run" position. Press on the pin and pull on the ignition switch lock cylinder to remove it.
  4. Disassemble and remove the instrument panel from the Taurus' interior. This includes the radio and all panels, electrical connectors, harnesses and screws. You'll need an assistant to help you lift and remove the instrument panel.
  5. Drain the engine coolant from the cooling system, using a clean container for reuse. Remove the heater hoses, actuator and metal cover from the heater. Disengage the spring from the heater core cover and the lever.
  6. Depress the locking ramp and remove the lever from the secondary air temperature control (the lever is brittle, so don't bend it). Remove the primary air conditioning air temperature control door shaft from the pin.
  7. Remove the heater core cover and seal from the heater/air conditioning housing assembly. Remove the heater core from the heater/air conditioning housing by pressing on the core tubes and assembly.
  8. Installation
  9. Install the replacement heater core to the heater/air conditioning housing. Install the core cover, seal, lever, spring, metal cover, actuator and heater hoses.
  10. Replace and assemble the instrument panel with your assistant's help. Connect the steering wheel (use a new bolt to connect it to the column), air bag and negative battery cable.
  11. Refill the cooling system with either the old coolant or new. Start the Taurus' engine and let it reach normal operating temperature. Watch the climate control operation and check for any leaks.
Read more: How to Replace the Heater Core in a Ford Taurus ' eHow.com http://www.ehow.com/how_4521301_replace-heater-core-ford-taurus.html#ixzz132BljfG8
Oct 21, 2010 | Ford Taurus Cars & Trucks
Shut off electric current from the breaker switch to Rheem electric water heater for the summer on May 2, 2010 since no hot water needed for the summer. In an attempt to turn on the breaker switch to the...
hi, might want check the thermostat switch, and the heating element. the heating might rusted out, if water wasn't drain out over summer thanks.
Sep 28, 2010 | Rheem Water Heaters
Left Heater switched on over night, oil radiator de longhi dragon
1st, check the electrical cord plug; because of the hielectric demand, thesaes plugs overheat and form a burn coating on the prongs that stops the hilevel of electric but allows a small level ofalaectric that still lights the lights but no power for heat.
2nd, the thermostat is not making contact: it is a bi-metal contactor that sometimes burns or loses its strength and no matter where you turn it it wont work. You can simply cross the terminals of the thermostat to see if you get electric flowing (you have to open the oen housing to do this.
3rd, the element could be burned-out or (as often happens) the connection to the heat element burns-off. Again, you need to open the end housing and look, or take it to a small appliance repair place.
Oct 11, 2009 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
I need to know where the location of the thermostat is on a 1999 chrysler 300m so i can replace
The 2.7L engine lower radiator hose, connects to the thermostat housing.
To Remove:
1.Disconnect the Negative battery cable.
(Engine COLD!)
  1. Drain cooling system.
  2. Remove radiator lower hose from thermostat housing.
  3. Remove nuts from heater tube flange studs.
  4. Loosen starter bolt at heater tube bracket.
  5. Pull heater tube out of thermostat housing and position out of the way.
  6. Remove bolt and two studs.
  7. Remove thermostat housing, O-ring and thermostat.
  8. Remove thermostat housing bolts.
To install:
A.Clean gasket sealing surfaces.
B.Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  1. Install thermostat and seal into thermostat housing .
  2. If removed, install two studs.
  3. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  4. Lubricate new heater return tube O-ring with coolant.
  5. Position heater return tube flange over two studs. Install nuts.
  6. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  7. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  8. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  9. Refill cooling system.
  10. Inspect for leaks.
  11. Connect negative cable.
3.2 and 3.5L engines:
Disconnect the battery cable. (Again engine COLD)
  2. Raise vehicle on hoist.
  3. Disconnect electrical connectors from engine oil and power steering pressure switches.
  4. Disconnect radiator and heater hoses from thermostat housing.
  5. Remove thermostat housing bolts.
  6. Remove housing, thermostat, and gasket.
The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing, using a suitable hand held grinder. It is not necessary to restake the replacement thermostat, into the thermostat housing.
To Install:
From AutoZone Repair Guides
I feel this way, I can give you an accurate description, and have taken into account your safety.
May 12, 2009 | 1999 Chrysler 300M
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Vulcan oil heater
Some warnings:
Mar 26, 2008 | Heating & Cooling
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Heating & Cooling Logo
420 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
